03-09-2013 04:27 AM - edited 03-16-2019 04:10 PM
Hi all,
i need to connect 2 fax machines on 2 fxs port on router 2921 which is connecting to sip line at branch.
i don't want to involve call manager located at head office for fax machine, instead i want them to directly take 2 lines from 100 channel sip line to be used as fax lines
the lines to be used are 01 205 4488 and 01 205 4499
ip address 172.18.21.226
itsp address 172.18.21.225
codec g711 A-law
can any one help....
thanks in advance.....
Solved! Go to Solution.
03-13-2013 01:00 PM
you need to create voice translation profile to match the incoming called number
voice translation-rule 1
rule 1 /01205\(4488\)/ /\1/
rule 2 /01205\(4499\)/ /\1/
voice translation-profile fax-in
translate called 1
create incoming dial-peer
dial-peer voice 1 voip
incoming called-number .
translation-profile inoming fax-in
dtmf-relay sip-notify
no vad
create voice service voip config
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface fastEthernet0/0
bind media source-interface fasttEthernet0/0
registrar server expires max 600 min 60
create dial-peer for calls going to fxs ports
dial-peer voice 10 pots
destination-pattern 4488
forward-digits all
port 0/0/0
dial-peer voice 11 pots
destination-pattern 4499
forward-digits all
port 0/0/1
Anas
please rate if it is helpful
03-13-2013 01:00 PM
translate called 1
no vad
voice service voip
sip
forward-digits all
port 0/0/0
forward-digits all
port 0/0/1
Anas
