Configuring Cisco IP 8861
Divambe
Hello All,
Configuring ip phone 8861 to work with my 2921, CME v12.0
But the phone is stuck at registering, here is the config
voice register global
mode cme
source-address 10.100.200.254 port 5060
max-dn 400
max-pool 110
load 8861 fireware
authenticate register
authenticate realm CSCM
tftp-path flash:
create profile sync 0003225259392353
auto-register
voice register dn 1
number 251
name DON
voice register pool 1
busy-trigger-per-button 2
id mac 2C31.24C8.BB08
type 8861
number 1 dn 1
codec g711ulaw
Please can i have a simple config to make this phone work ?
3 Accepted Solutions
Georgios Fotiadis
Do you have these lines in your config:
voice service voip
 sip
  registrar server
Also, verify that option 150 in your DHCP config point to 10.100.200.254.
If yes, please, attach (as file) the output of these logs:
- debug ccsip messages
- debug voice register events
Georgios
Please rate if you find this helpful.
Danielzx11
I think you're issue is line six, that doesn't look right for a firMware name. Below is a simple sample config:
mode cme
source-address 192.168.10.1 port 5060
max-dn 20
max-pool 10
load 7970 SIP70.8-2-1S
load 3911 SIP3951.8-0-2-9
authenticate realm cisco.com
voicemail 100
tftp-path flash:
create profile sync 0000589556325309
voice register dn 1
number 101
call-forward b2bua noan 100 timeout 20
allow watch
name Phone1
label 4085251001
id mac 0016.47CD.9BD7
type 7970
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username user1 password cisco
codec g711ulaw
blf-speed-dial 2 102 label "Phone2"
blf-speed-dial 3 103 label "3911-1"
blf-speed-dial 4 104 label "3911-2"
Sorry I didn't include the line for a 8861 in that example, it should resemble the following depending on the firmware load you have
Load 8861 sip88xx.11-7-1-17
or
Load 8861 sip88xx.10-2-2-16
Unless of course your renamed your load "fireware"
5 Replies 5
Georgios Fotiadis
voice service voip
 sip
  registrar server
Georgios
here is the debug
*Jan 19 10:25:38.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:10.100.200.254 SIP/2.0
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK27752ddf
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb080015423a8a94-32c198d7
To: <sip:10.100.200.254>
Call-ID: 2c3124c8-bb080012-57a2067e-4dec3016@10.100.200.1
Session-ID: 47e40e7000105000a0002c3124c8bb08;remote=0000000000000000000000000000 0000
Date: Fri, 20 Jan 2017 07:36:40 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8861/11.7.1
Expires: 10
Max-Forwards: 70
Contact: <sip:82D8-16FE@10.100.200.1:5060;transport=udp>;+u.sip!devicename.ccm.c isco.com="SEP2C3124C8BB08"
Require: norefersub
Referred-By: "DON " <sip:251@10.100.200.1>
Refer-To: cid:3b554bd9@10.100.200.1
Content-Id: <3b554bd9@10.100.200.1>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 507
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="DeviceTLInfo">
<ParameterList>
<String name="DeviceName">SEP2C3124C8BB08</String>
<String name="IPv4Address">10.100.200.1</String>
<String name="IPv6Address"></String>
<String name="CTL_Signature">Not Installed</String>
<String name="CTL_TFTP_Server">N/A</String>
<String name="ITL_Signature">Not Installed</String>
<String name="ITL_TFTP_Server">N/A</String>
<String name="StatusCode">6</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.315: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK5f97c002
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb0800167ea7afe7-3742c5a7
Call-ID: 2c3124c8-bb080013-019d21ba-5f251627@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:6c7e4213@10.100.200.1
Content-Id: <6c7e4213@10.100.200.1>
Content-Length: 388
<x-cisco-alarm>
<Alarm Name="DeviceImageDownloadStart">
<ParameterList>
<String name="Active">sip88xx.11-7-1-17</String>
<String name="RequestedLoadId">fireware</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.319: VOICE_REG_POOL: No entry for (251) found in contact table
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK6bb9f248
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb08001709699b1f-449f125c
Call-ID: 2c3124c8-bb080014-3d63c147-361ef2c2@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:0ff42dce@10.100.200.1
Content-Id: <0ff42dce@10.100.200.1>
Content-Length: 1540
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceIPv4Address">10.100.200.1/24</String>
<String name="IPv4DefaultGateway">10.100.200.254</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8861</String>
<String name="NeighborIPv4Address">10.100.200.254</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID">yourname.yourdomain.com</String>
<String name="NeighborPortID">GigabitEthernet0/0</String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">0</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN"></String>
<String name="UnifiedCMIPAddress"></String>
<String name="LocalPort">0</String>
<String name="TimeStamp">1484897444178</String>
<Enum name="ReasonForOutOfService">24</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:10.100.200.254 SIP/2.0 C seq:101 REGISTER CallId:2c3124c8-bb080002-0510c500-70985ec5@10.100.200.1 </St ring>
<String name="LastProtocolEventReceived"></String>
<String name="ReasonForOutOfServiceText">LastTimePhoneRegRej</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.331: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK450e16ac
From: <sip:251@10.100.200.254>;tag=2c3124c8bb0800185f15bbbe-1957b4bc
To: <sip:251@10.100.200.254>
Call-ID: 2c3124c8-bb080005-00589a24-05bd52f9@10.100.200.1
Max-Forwards: 70
CSeq: 104 REGISTER
Contact: <sip:82D8-16FE@10.100.200.1:5060;transport=udp>;+sip.instance="<urn:uui d:00000000-0000-0000-0000-2c3124c8bb08>";+u.sip!devicename.ccm.cisco.com="SEP2C3 124C8BB08";+u.sip!model.ccm.cisco.com="685"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X- cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X- cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi- 8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEP2C3124C8BB08 ActiveLoad=sip88 xx.11-7-1-17.loads InactiveLoad=cert.os.mfg.drop Last=phone-reg-rej"
Expires: 3600
*Jan 19 10:25:38.331: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.331: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.331: auth absent
*Jan 19 10:25:38.331: VOICE_REG_POOL: key(B5FC93BF00009EAD) added to nonce table
*Jan 19 10:25:38.331: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:251@10.100.200.254>;tag=632C4-1F97
Date: Fri, 19 Jan 2018 10:25:38 GMT
Server: Cisco-SIPGateway/IOS-15.7.3.M1
CSeq: 104 REGISTER
WWW-Authenticate: Digest realm="CSCM",nonce="B5FC93BF00009EAD",algorithm=MD5,qop ="auth"
Content-Length: 0
*Jan 19 10:25:38.335: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK5bd386ca
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb08001966bf0555-174f1e03
Call-ID: 2c3124c8-bb080015-26140f29-0a6d9e26@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:19050d08@10.100.200.1
Content-Id: <19050d08@10.100.200.1>
Content-Length: 548
<x-cisco-alarm>
<Alarm Name="DeviceImageDownloadFailure">
<ParameterList>
<Enum name="Method">3</Enum>
<Enum name="FailureReason">2</Enum>
<String name="Inactive">cert.os.mfg.drop</String>
<String name="FailedLoadId">fireware</String>
<String name="Server">10.100.200.254</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.335: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK06b80bda
Max-Forwards: 70
CSeq: 105 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="3c08ac303189e82b7400b474629febce",nonce="B5FC93BF00009EAD",cnonce="3d9d46f9",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.343: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.343: auth present
*Jan 19 10:25:38.343: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.343: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 105 REGISTER
Content-Length: 0
*Jan 19 10:25:38.359: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK705edfd0
Max-Forwards: 70
CSeq: 106 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="72634c06ce9655516511b882713e8bb5",nonce="B5FC93BF00009EAD",cnonce="5b3f979d",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.359: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.359: auth present
*Jan 19 10:25:38.359: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.363: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 106 REGISTER
Content-Length: 0
*Jan 19 10:25:38.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK292bc7b3
Max-Forwards: 70
CSeq: 107 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="37b2856387411b75da4e4660de7cdd5c",nonce="B5FC93BF00009EAD",cnonce="5e5a1258",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.371: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.371: auth present
*Jan 19 10:25:38.371: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.371: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 107 REGISTER
Content-Length: 0
*Jan 19 10:25:38.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK19af5e32
Max-Forwards: 70
CSeq: 108 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="c2b732a9171899ff1015d78d0b4a5e37",nonce="B5FC93BF00009EAD",cnonce="17d40daf",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.379: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.379: auth present
*Jan 19 10:25:38.379: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.379: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 108 REGISTER
Content-Length: 0
*Jan 19 10:25:38.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK4f16d356
Max-Forwards: 70
CSeq: 109 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="3e9eee843e611d62729f40eb9df6dee4",nonce="B5FC93BF00009EAD",cnonce="27d3779b",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.387: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.387: auth present
*Jan 19 10:25:38.387: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.387: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 109 REGISTER
Content-Length: 0
*Jan 19 10:25:38.823: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 507
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.823: VOICE_REG_POOL: No entry for (251) found in contact table
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 388
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.827: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 548
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.835: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:39.819: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
^@-^^@-^^@-^^@-^.200.254 SIP/2.0
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 507
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
.n.o>is)..`)E`
*Jan 19 10:25:39.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 388
Content-Dispos.n.o>:)..x.Ex.E........YE...
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
<String name="LastProtocolEventSent">Sent:REGISTER sip:10.100.200.254 SIP/2.0 C seq:101 REGISTER CallId:2c3124c8-bb080002-0510c500-70985ec5@10.100.200.1 </St r.n.o>y..ing name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 548
Content-Type: application/x.n.o>oi..`E`E........4rD...ion: session;handling=requ ired
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:41.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
<String name="ReasonForOutOfServiceText".n.o>i...
rD
Danielzx11
mode cme
max-dn 20
max-pool 10
voicemail 100
tftp-path flash:
voice register dn 1
number 101
allow watch
name Phone1
label 4085251001
type 7970
number 1 dn 1
presence call-list
codec g711ulaw
or
Thanks it works,phones can register now
