01-18-2018 09:19 AM - edited 03-17-2019 11:59 AM
Hello All,
Configuring ip phone 8861 to work with my 2921, CME v12.0
But the phone is stuck at registering, here is the config
voice register global
mode cme
source-address 10.100.200.254 port 5060
max-dn 400
max-pool 110
load 8861 fireware
authenticate register
authenticate realm CSCM
tftp-path flash:
create profile sync 0003225259392353
auto-register
voice register dn 1
number 251
name DON
voice register pool 1
busy-trigger-per-button 2
id mac 2C31.24C8.BB08
type 8861
number 1 dn 1
codec g711ulaw
Please can i have a simple config to make this phone work ?
Solved! Go to Solution.
01-18-2018 09:55 AM
Do you have these lines in your config:
voice service voip sip registrar server
Also, verify that option 150 in your DHCP config point to 10.100.200.254.
If yes, please, attach (as file) the output of these logs:
- debug ccsip messages
- debug voice register events
01-18-2018 11:51 AM
I think you're issue is line six, that doesn't look right for a firMware name. Below is a simple sample config:
mode cme
source-address 192.168.10.1 port 5060
max-dn 20
max-pool 10
load 7970 SIP70.8-2-1S
load 3911 SIP3951.8-0-2-9
authenticate realm cisco.com
voicemail 100
tftp-path flash:
create profile sync 0000589556325309
voice register dn 1
number 101
call-forward b2bua noan 100 timeout 20
allow watch
name Phone1
label 4085251001
id mac 0016.47CD.9BD7
type 7970
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username user1 password cisco
codec g711ulaw
blf-speed-dial 2 102 label "Phone2"
blf-speed-dial 3 103 label "3911-1"
blf-speed-dial 4 104 label "3911-2"
01-18-2018 11:56 AM
Sorry I didn't include the line for a 8861 in that example, it should resemble the following depending on the firmware load you have
Load 8861 sip88xx.11-7-1-17
or
Load 8861 sip88xx.10-2-2-16
Unless of course your renamed your load "fireware"
01-18-2018 09:55 AM
01-19-2018 02:43 AM
here is the debug
*Jan 19 10:25:38.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:10.100.200.254 SIP/2.0
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK27752ddf
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb080015423a8a94-32c198d7
To: <sip:10.100.200.254>
Call-ID: 2c3124c8-bb080012-57a2067e-4dec3016@10.100.200.1
Session-ID: 47e40e7000105000a0002c3124c8bb08;remote=0000000000000000000000000000 0000
Date: Fri, 20 Jan 2017 07:36:40 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8861/11.7.1
Expires: 10
Max-Forwards: 70
Contact: <sip:82D8-16FE@10.100.200.1:5060;transport=udp>;+u.sip!devicename.ccm.c isco.com="SEP2C3124C8BB08"
Require: norefersub
Referred-By: "DON " <sip:251@10.100.200.1>
Refer-To: cid:3b554bd9@10.100.200.1
Content-Id: <3b554bd9@10.100.200.1>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 507
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="DeviceTLInfo">
<ParameterList>
<String name="DeviceName">SEP2C3124C8BB08</String>
<String name="IPv4Address">10.100.200.1</String>
<String name="IPv6Address"></String>
<String name="CTL_Signature">Not Installed</String>
<String name="CTL_TFTP_Server">N/A</String>
<String name="ITL_Signature">Not Installed</String>
<String name="ITL_TFTP_Server">N/A</String>
<String name="StatusCode">6</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.315: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK5f97c002
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb0800167ea7afe7-3742c5a7
Call-ID: 2c3124c8-bb080013-019d21ba-5f251627@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:6c7e4213@10.100.200.1
Content-Id: <6c7e4213@10.100.200.1>
Content-Length: 388
<x-cisco-alarm>
<Alarm Name="DeviceImageDownloadStart">
<ParameterList>
<String name="Active">sip88xx.11-7-1-17</String>
<String name="RequestedLoadId">fireware</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.319: VOICE_REG_POOL: No entry for (251) found in contact table
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK6bb9f248
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb08001709699b1f-449f125c
Call-ID: 2c3124c8-bb080014-3d63c147-361ef2c2@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:0ff42dce@10.100.200.1
Content-Id: <0ff42dce@10.100.200.1>
Content-Length: 1540
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceIPv4Address">10.100.200.1/24</String>
<String name="IPv4DefaultGateway">10.100.200.254</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8861</String>
<String name="NeighborIPv4Address">10.100.200.254</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID">yourname.yourdomain.com</String>
<String name="NeighborPortID">GigabitEthernet0/0</String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">0</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN"></String>
<String name="UnifiedCMIPAddress"></String>
<String name="LocalPort">0</String>
<String name="TimeStamp">1484897444178</String>
<Enum name="ReasonForOutOfService">24</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:10.100.200.254 SIP/2.0 C seq:101 REGISTER CallId:2c3124c8-bb080002-0510c500-70985ec5@10.100.200.1 </St ring>
<String name="LastProtocolEventReceived"></String>
<String name="ReasonForOutOfServiceText">LastTimePhoneRegRej</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.331: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK450e16ac
From: <sip:251@10.100.200.254>;tag=2c3124c8bb0800185f15bbbe-1957b4bc
To: <sip:251@10.100.200.254>
Call-ID: 2c3124c8-bb080005-00589a24-05bd52f9@10.100.200.1
Max-Forwards: 70
CSeq: 104 REGISTER
Contact: <sip:82D8-16FE@10.100.200.1:5060;transport=udp>;+sip.instance="<urn:uui d:00000000-0000-0000-0000-2c3124c8bb08>";+u.sip!devicename.ccm.cisco.com="SEP2C3 124C8BB08";+u.sip!model.ccm.cisco.com="685"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X- cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X- cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi- 8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEP2C3124C8BB08 ActiveLoad=sip88 xx.11-7-1-17.loads InactiveLoad=cert.os.mfg.drop Last=phone-reg-rej"
Expires: 3600
*Jan 19 10:25:38.331: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.331: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.331: auth absent
*Jan 19 10:25:38.331: VOICE_REG_POOL: key(B5FC93BF00009EAD) added to nonce table
*Jan 19 10:25:38.331: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:251@10.100.200.254>;tag=632C4-1F97
Date: Fri, 19 Jan 2018 10:25:38 GMT
Server: Cisco-SIPGateway/IOS-15.7.3.M1
CSeq: 104 REGISTER
WWW-Authenticate: Digest realm="CSCM",nonce="B5FC93BF00009EAD",algorithm=MD5,qop ="auth"
Content-Length: 0
*Jan 19 10:25:38.335: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK5bd386ca
From: "DON " <sip:251@10.100.200.1>;tag=2c3124c8bb08001966bf0555-174f1e03
Call-ID: 2c3124c8-bb080015-26140f29-0a6d9e26@10.100.200.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:19050d08@10.100.200.1
Content-Id: <19050d08@10.100.200.1>
Content-Length: 548
<x-cisco-alarm>
<Alarm Name="DeviceImageDownloadFailure">
<ParameterList>
<Enum name="Method">3</Enum>
<Enum name="FailureReason">2</Enum>
<String name="Inactive">cert.os.mfg.drop</String>
<String name="FailedLoadId">fireware</String>
<String name="Server">10.100.200.254</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.335: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK06b80bda
Max-Forwards: 70
CSeq: 105 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="3c08ac303189e82b7400b474629febce",nonce="B5FC93BF00009EAD",cnonce="3d9d46f9",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.343: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.343: auth present
*Jan 19 10:25:38.343: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.343: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 105 REGISTER
Content-Length: 0
*Jan 19 10:25:38.359: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK705edfd0
Max-Forwards: 70
CSeq: 106 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="72634c06ce9655516511b882713e8bb5",nonce="B5FC93BF00009EAD",cnonce="5b3f979d",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.359: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.359: auth present
*Jan 19 10:25:38.359: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.363: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 106 REGISTER
Content-Length: 0
*Jan 19 10:25:38.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK292bc7b3
Max-Forwards: 70
CSeq: 107 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="37b2856387411b75da4e4660de7cdd5c",nonce="B5FC93BF00009EAD",cnonce="5e5a1258",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.371: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.371: auth present
*Jan 19 10:25:38.371: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.371: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 107 REGISTER
Content-Length: 0
*Jan 19 10:25:38.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK19af5e32
Max-Forwards: 70
CSeq: 108 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="c2b732a9171899ff1015d78d0b4a5e37",nonce="B5FC93BF00009EAD",cnonce="17d40daf",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.379: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.379: auth present
*Jan 19 10:25:38.379: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.379: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 108 REGISTER
Content-Length: 0
*Jan 19 10:25:38.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.100.200.1:5060;branch=z9hG4bK4f16d356
Max-Forwards: 70
CSeq: 109 REGISTER
Authorization: Digest username="",realm="CSCM",uri="sip:10.100.200.254",response ="3e9eee843e611d62729f40eb9df6dee4",nonce="B5FC93BF00009EAD",cnonce="27d3779b",q op=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Jan 19 10:25:38.387: VOICE_REG_POOL: Register request for (251) from (10.100.20 0.1)
*Jan 19 10:25:38.387: auth present
*Jan 19 10:25:38.387: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.387: //1/ED56E3EA8005/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 109 REGISTER
Content-Length: 0
*Jan 19 10:25:38.823: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 507
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.823: VOICE_REG_POOL: No entry for (251) found in contact table
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 388
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.827: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:38.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 548
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:38.835: VOICE_REG_POOL: No entry for (251) found in contact table
*Jan 19 10:25:39.819: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
^@-^^@-^^@-^^@-^.200.254 SIP/2.0
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 507
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
.n.o>is)..`)E`
*Jan 19 10:25:39.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 388
Content-Dispos.n.o>:)..x.Ex.E........YE...
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
<String name="LastProtocolEventSent">Sent:REGISTER sip:10.100.200.254 SIP/2.0 C seq:101 REGISTER CallId:2c3124c8-bb080002-0510c500-70985ec5@10.100.200.1 </St r.n.o>y..ing name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Content-Length: 548
Content-Type: application/x.n.o>oi..`E`E........4rD...ion: session;handling=requ ired
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Jan 19 10:25:41.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
<String name="ReasonForOutOfServiceText".n.o>i...
rD
01-18-2018 11:51 AM
mode cme
max-dn 20
max-pool 10
voicemail 100
tftp-path flash:
voice register dn 1
number 101
allow watch
name Phone1
label 4085251001
type 7970
number 1 dn 1
presence call-list
codec g711ulaw
01-18-2018 11:56 AM
or
01-19-2018 03:52 AM
Thanks it works,phones can register now
