01-09-2009 10:13 PM - edited 03-15-2019 03:26 PM
I have a Cisco 3825 Voice Bundle Router with 2XPVDM2-64 (Total 128), I have installed 3 VWIC2-2MFT-T1/E1. Now I have to configure 4 E1's but after configuring Two E1's for the third E1 the Router is giving me an error as given below:
% Not enough DSP resources available to configure ds0-group 0 on controller E1 0/1/0
% The remaining dsp resources are enough for 8 time slots.
% For current codec complexity, 1 extra dsp(s) are required to create this voice port.
While designing I made sure of PVDM's & added one more PVDM2-64.
Do I require to configure or bundle these PVDM's I am giving below my configurations for Voice-card 0 & 1.
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
Solved! Go to Solution.
01-11-2009 08:50 AM
Each E1's configured uses 30 channels, since you have 4 already UP you are using 120 channels hence you only have 8 channels remaining from the 128 of the 2 PVDM2-64
You will need to add one more PVDM2-64 to configure the other 2 E1's
DSP calculator can show you more details
www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
Txs
Pedro
01-09-2009 11:27 PM
What do you see with 'show diag' command in your router?
01-09-2009 11:56 PM
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.2
Part Number : 73-8541-04
Board Revision : A0
Deviation Number : 0
Fab Version : 03
PCB Serial Number : FOC09503V4G
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
Version Identifier : NA
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 EC 41 03 02 82 49 21 5D 04 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 39 35 30
0x20: 33 56 34 47 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 4E 41 20 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC1030375M
RMA History : 00
Processor type : 00
Version Identifier : V01
0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 33 30
0x20: 33 37 35 4D 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
01-10-2009 11:29 AM
If you're not using a low-complexity codec you might need more DSPs. If you're using G.729, faxing, G.722 or a number of other codecs, there's a good chance it would require more DSPs.
'show voice dsp group all' is an excellent command for showing your DSP resources.
Check out your requirements in the DSP calculator, and make sure you determine your codec requirements correctly:
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
hth,
nick
01-10-2009 11:34 AM
If you added dsp services dspfarm is because you added also dspfarm profiles, which consume dsp resources as well.
The two pvdm2-64 should be enough even for 4 E1's so it must be dspfarm profiles consuming them.
send sh run to check your config or if you have dspfarm profiles (and don't use them) delete them.
regards
01-11-2009 04:53 AM
01-11-2009 08:50 AM
Txs
Pedro
01-13-2009 03:45 AM
As a rule of thumb always consider One PVDM2-64 for 2 E1s.
Now you have 6 E1's hence you need to have three numbers of PVDM2-64.
As pointed by Pedro, since you have 2 PVDM2-64 you'll be able to configure 4 E1 interfaces. Any additional e1 will call for additional PVDM.
-> Sushil
