CONNECTING IP PHONES REMOTELY
meyofmarksog1
Hi Engineers and experts,
I have been working on a project. i decided to simulate(packet tracer 7) a network with several branches. I am stuck with the configuration of voice. the cloud is a router that does routing. i used EIGRP as routing protocol. i have been able to get them communicate within their branches. but they cannot communicate outside their WAN links with the other branches. What advise can you give me?
Jaime Valencia
You'll have to more specific, this seems to be more of a routing problem than a VoIP problem.
VoIP just assumes you'll have all your routing configured to have the IP Phones reach your CUCM server, and the ability to route the RTP directly between endpoints, and have QoS if required so voice has the right priority.
java
if this helps, please rate
meyofmarksog1
To enable the various VOIP phones to communicate i configure several "dialer-pairs" with other branches.
it was a mesh approach. i wonder if there is a better way to do the configuration.
THE VOIP PHONES IN BRANCH "a"
dial-peer voice 3 voip
destination-pattern 7200.
session target ipv4:50.51.1.1
dial-peer voice 4 voip
destination-pattern 7100.
session target ipv4:9.10.9.2
dial-peer voice 5 voip
destination-pattern 7500.
session target ipv4:90.91.1.1
dial-peer voice 9 voip
destination-pattern 7300.
session target ipv4:70.71.1.1
telephony-service
max-ephones 10
max-dn 5
ip source-address 172.18.9.1 port 2003
ephone-dn 1
number 74001
ephone-dn 2
number 74002
ephone-dn 3
number 74003
ephone-dn 4
number 74004
ephone 1
device-security-mode none
mac-address 000C.85A3.1374
type 7960
button 1:1
ephone 2
mac-address 0001.630E.D27D
type 7960
button 1:2
ephone 3
mac-address 00D0.97E0.304A
type 7960
button 1:3
ephone 4
mac-address 00D0.BAD7.C6D2
type 7960
button 1:4
