Hey!
So Im just an amateur who just wants to set up an CISCO CP-7941G in home and I have a quick question.
I have a VOIP SIP Account and I just found the IP Phone mentioned above (no power adapter though).
Is it possible (and if so - how to do it) to make the phone use only PC power (POE) and internet connection?
My point is, Im using WiFi router a bit far from the place I'd like to set the phone, so I want just to plug it into the PC via ethernet cable. That means powering it via this cable (POE) and make it use PC just like router (as long as the PC is on - the phone will have the connection). Is this even possible? How to make it use the PC as router? Will I need any addictional software?
Please help!
Allright, but can I use the same RJ-45 slot for both - POE and Internet connection?
Also,
I can configure the SIP domain etc. via phone, not only via some PC software, can't I?
That is correct.
You can use a software-based phone (aka softphone) and configure it for IP telephony on your PC.
Yes yes, what Im asking about is configuring the Cisco phone itself.
You will need several items to get this to work:
