Converting Hex to String on Dial-peer Level for SIP Parameters
Senthil Kumar Sankar
Hi All,
Is there any command in the Voice Gateway to accomplish the below task.
When the Call hits in the CUBE and when matches the Incoming Dial-Peer and we see the below UUI header information in the SIP INVITE
User-to-User: 30303931323436;encoding=hex
When the call goes out thru the Outbound Dial-peer, is there a way i can convert this back to String.
Have anyone tried this via Sip Normalization. Can someone give me a clue.
Senthil
5 Replies 5
paolo bevilacqua
That cannot be done, because standard dictates no other encoding option than 'hex'.
http://tools.ietf.org/html/draft-ietf-cuss-sip-uui-04
http://tools.ietf.org/html/draft-ietf-cuss-sip-uui-isdn-04
Hi Paolo,
Thanks for the information. I have referred this RFC. But is there any other way i can accomplish this.
I would be sending this info to a Contact Centre Environment(CVP Component or a Cisco Sip Proxy Server).
Senthil
And what is that you want to accomplish ?
When the SIP Invite passes to the next hop, the value should be converted from
to
User-to-User: 091246
Senthil
As answered above already:
per draft standard, that is not allowed.
You can read the standard  youself:
 If the "encoding" parameter is not present, "hex" MUST be assumed.
