12-12-2016 10:57 PM - edited 03-17-2019 08:56 AM
Gentleman
i m not expert in cisco ip telephone system
we want to block outgoing PSTN call for particular ephones .Cisco CME system.
we have 7 PSTN lines , currently outgoing call activated only one line its belongs to voice 0/0/0.
i was tried to apply using by core list but it was failed. please help. cause im confused pots and voip system.
also if we activate outgoing calls one of 0/0/1 how to set it particular ephones
my configuration given below.
dial-peer cor custom
name Emergency
name local
name mobile
name national
name Tollfree
dial-peer cor list Emergency
member Emergency
dial-peer cor list local
member local
dial-peer cor list mobile
member mobile
dial-peer cor list national
member national
dial-peer cor list DFP-VIP
member Emergency
member local
member mobile
member national
member Tollfree
dial-peer cor list DFP-ALL
member Emergency
member local
member Tollfree
dial-peer cor list Tollfree
member Tollfree
dial-peer voice 511 voip
destination-pattern 500
session target ipv4:172.30.144.2
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 500 voip
service aa
incoming called-number 500
codec g711ulaw
dial-peer voice 100 voip
destination-pattern 200
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session target ipv4:172.30.144.36
incoming called-number .
codec g711ulaw
fax rate disable
no vad
dial-peer voice 2 voip
dial-peer voice 1 voip
destination-pattern 1..
codec g711ulaw
no vad
dial-peer voice 10 pots
corlist outgoing mobile
destination-pattern 0T
port 0/0/0
dial-peer voice 11 pots
destination-pattern 9T
port 0/0/1
dial-peer voice 12 pots
port 0/0/2
dial-peer voice 13 pots
port 0/0/3
dial-peer voice 14 pots
port 0/1/0
dial-peer voice 15 pots
port 0/1/1
dial-peer voice 16 pots
port 0/1/2
dial-peer voice 17 pots
port 0/1/3
gatekeeper
shutdown
telephony-service
video
no auto-reg-ephone
max-ephones 57
max-dn 57
ip source-address 172.30.144.2 port 2000
max-redirect 5
system message DFP
modem passthrough nse payload 98
cnf-file location flash:
load 7945 SCCP45.9-2-1S
max-conferences 8 gain -6
moh "music-on-hold.au"
web admin system name admin secret 5 $1$2XdX$hmOF1siKsFM.cWOwQslGP0
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Dec 04 2016 10:02:13
ephone-dn 1 dual-line
number 139
label Babur Ali
name Babur Ali
allow watch
call-forward noan 00531335709 timeout 15
ephone-dn 2 dual-line
number 118
label Saleh Hamad
description Saleh Hamad
name Saleh Hamad
allow watch
call-forward noan 117 timeout 15
Solved! Go to Solution.
12-14-2016 04:58 AM
+5 to Jitendra for sharing an accurate information.
Please note that you should apply corlist to ephone in inbound direction as any outgoing call from ephone is inbound dial peer from CME perspective. Change the command under ephone from 'corlist outgoing' to 'corlist incoming'. I have not looked at complete config but assume that you've created corlist correctly as per your requirement.
- Vivek
PS: Please share config only as attachment, don't post the full config under the thread.
12-14-2016 12:13 AM
see below, they would help you understand COR in grater detail and help troubleshoot the issue.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
https://www.youtube.com/watch?v=4g63CKMGac4
JB
12-14-2016 04:58 AM
Thanks for your comment,
however i had tried to below configuration. still all ephones can able to call outgoing PSTN
name Emergency
name local
name mobile
name national
name Tollfree
member Emergency
member local
member mobile
member national
member Tollfree
dial-peer cor list External
member Emergency
member local
member mobile
member national
member Tollfree
dial-peer cor list Internal
member Emergency
member local
member Tollfree
codec g711ulaw
service aa
codec g711ulaw
corlist outgoing External
codec g711ulaw
fax rate disable
no vad
corlist outgoing Internal
codec g711ulaw
no vad
port 0/0/0
port 0/0/1
port 0/0/2
port 0/0/3
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
ephone-dn 49
number 125
label Conference Room C
description Conference Room C
name Conference Room C
allow watch
12-14-2016 04:58 AM
- Vivek
12-14-2016 06:20 AM
Thakns again for your prompt respond, its highly appreciated,
Active out going PSTN Line connected over port 0/0/0
i believe below configuration shall be ok...
port 0/0/0
number 118
name Saleh Hamad
allow watch
corlist incoming External
my intention is block out going PSTN call for particula ephone
Also let me know , should i change anything in voice voip?
