Corporate Directory association with ANI
flex_serg
I am just wondering, if there is a way to make the following thing work:
- CUCM 7.1 End User Database is synchronized with corporate Microsoft AD
- most end users have Telephone Number field filled with their DNs, or DNs and cell phone numbers
- when call comes in and ANI comes with it can CUCM be set so that this ANI would be associated with corresponding end user name and the name would be displayed on IP Phone rather than ANI.
If any references to any other sources will be provided, it will be very helpful as well.
Thanks for help.
Jaime Valencia
We currently do not provide that feature/integration, if you would like to see it in a future version get in touch with your CAM and submit a PER.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
