11-15-2013 12:35 PM - edited 03-16-2019 08:26 PM
I'm using CounterPath Bria iPhone 3.0.1 with my CME 8.6 and it works fine. However, it seems that only one DN is supported. When calling the second extension (4000) the iPhone doesn't ring. Has anyone got this working?
voice register dn 4
number 4000
name Johannes (iPhone)
no-reg
label ISDN/intern (SDN4)
voice register dn 5
number 5000
no-reg
label ISDN/intern (SDN5)
voice register pool 5
id mac 5555.5555.5555
number 1 dn 5
number 2 dn 4
template 1
presence call-list
dtmf-relay rtp-nte
username 5000 password <removed>
description x5000
codec g722-64
no vad
Solved! Go to Solution.
11-15-2013 01:28 PM
Hi Johannes.
Did you register also the second line on softphone as another account?
Let me know.
Carlo
11-15-2013 01:28 PM
Hi Johannes.
Let me know.
Carlo
11-17-2013 01:14 PM
Hi Carlo,
thanks, I didn't see this obvious solution. I made two accounts and it works.
