CP 3905 unprovisioned
amine.onetech
HI,
i have a CME solution containing 50 cisco SIP phones 3905, everything seems ok with the configuration since a lot of those phones registered, the problem that i have like 15 phones that kept having the message "provisioning", i verified the voice register pool and it seems correct.
Any idea? this is a part of my startup config :
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-3.T3.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock calendar-valid
no ipv6 cef
ip dhcp excluded-address 10.16.150.253
ip dhcp pool Voix
network 10.16.150.0 255.255.255.0
option 150 ip 10.16.150.253
default-router 10.16.150.253
ip domain name yourdomain.com
ip cef
trunk group PSTN
trunk group PSTN2
crypto pki trustpoint TP-self-signed-2313754983
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2313754983
revocation-check none
rsakeypair TP-self-signed-2313754983
voice-card 0
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server
voice register global
mode cme
source-address 10.16.150.253 port 5060
max-dn 400
max-pool 110
load 6921 SIP69xx.9-3-1-5
load 3905 CP3905.9-2-1-0
timezone 22
create profile sync 0536963455032434
network-locale FR
user-locale FR
ntp-server 10.16.150.253 mode directedbroadcast
voice register dn  1
number 101
name Ferid ElKsouri
label Ferid ElKsouri
voice register dn  2
number 142
name Mouna Mami
label Mouna Mami
voice register dn  3
number 110
name Meriyam OKBI
label Meriyam OKBI
voice register dn  4
number 102
name Mme Hedda
label Mme Hedda
voice register dn  5
number 122
name Tarek Belabe & Wahbi Boujemaa
label Tarek Belabe & Wahbi Boujemaa
voice register dn  6
number 9
name Standard/Bureau d'ordre
label Standard/Bureau d'ordre
voice register dn  7
number 118
name Faycal Chaaba
label Faycal Chaaba
voice register dn  8
number 119
name Amor Jlassi
label Amor Jlassi
voice register dn  9
number 120
name Nessrine Mechihci
label Nessrine Mechihci
voice register dn  10
number 130
name Walid Zouari & Dorsaf Ben Amor
label Walid Zouari & Dorsaf Ben Amor
voice register dn  11
number 139
name Sawssen Aouadi & Moez Zaltni
label Sawssen Aouadi & Moez Zaltni
voice register dn  12
number 158
name Meriam Slaimi
label Meriam Slaimi
voice register dn  13
number 159
name Chouaieb Ajmi
label Chouaieb Ajmi
voice register dn  14
number 131
name Said Jaouadi
label Said Jaouadi
voice register dn  15
number 152
name Fahd Essid
label Fahd Essid
voice register dn  16
number 155
name Omar Jemel
label Omar Jemel
voice register dn  17
number 133
name Imen Azzaiez
label Imen Azzaiez
voice register dn  18
number 144
name Ghazi Bekri
label Ghazi Bekri
voice register dn  19
number 145
name Mourad Chaabane
label Mourad Chaabane
voice register dn  20
number 168
name Med Ridha Gezmir
label Med Ridha Gezmir
voice register dn  21
number 111
name Mohamed Kratou
label Mohamed Kratou
voice register dn  22
number 115
name Taher Kammoun
label Taher Kammoun
voice register dn  23
number 116
name KamelHantous&H.Trabelsi
label KamelHantous&H.Trabelsi
voice register dn  24
number 132
name Assima Kraiem & Mehdi Ajmi
label Assima Kraiem & Mehdi Ajmi
voice register dn  25
number 127
name Moez Morsni & Said Saidani
label Moez Morsni & Said Saidani
voice register dn  26
number 178
name Nejmeddine Benoun
label Nejmeddine Benoun
voice register dn  27
number 108
name Gardien Poste1
label Gardien Poste1
voice register dn  28
number 143
name Yosra Ben Amer
label Yosra Ben Amer
voice register dn  29
number 146
name Nozha Ben Chaabene
label Nozha Ben Chaabene
voice register dn  30
number 162
name Gardien Poste2
label Gardien Poste2
voice register dn  31
number 117
name LCM Malika Mrabet&Chadia Touil
label LCM Malika Mrabet&Chadia Touil
voice register dn  32
number 123
name Awatef Ben Othmen
label Awatef Ben Othmen
voice register dn  33
number 124
name Jihen Bedoui&S.Ben Jaafer
label Jihen Bedoui&S.Ben Jaafer
voice register dn  34
number 125
name Labo LCQ
label Labo LCQ
voice register dn  35
number 128
name Dalenda Bouslah
label Dalenda Bouslah
voice register dn  36
number 135
name Mehdi Sahbi
label Mehdi Sahbi
voice register dn  37
number 136
name Skander Cherif
label Skander Cherif
voice register dn  38
number 137
name Hanen Abidi
label Hanen Abidi
voice register dn  39
number 140
name Imen Mejri
label Imen Mejri
voice register dn  40
number 138
name Hatem Zaheni
label Hatem Zaheni
voice register dn  41
number 114
name Oussama Sanakli
label Oussama Sanakli
voice register dn  42
number 121
name Adel Sbaouelji
label Adel Sbaouelji
voice register dn  43
number 141
name Moncef Trabelsi
label Moncef Trabelsi
voice register dn  44
number 148
name Bloc H
label Bloc H
voice register dn  45
number 149
name Maintenance Process
label Maintenance Process
voice register dn  46
number 150
name Controle Volant
label Controle Volant
voice register dn  47
number 151
name Manel Othmani
label Manel Othmani
voice register dn  48
number 153
name Adel Zaiem (Bloc B)
label Adel Zaiem (Bloc B)
voice register dn  49
number 154
name Afef Hmaidi (Bloc A)
label Afef Hmaidi (Bloc A)
voice register dn  50
number 160
name Yousri Ben Younes
label Yousri Ben Younes
voice register dn  51
number 161
name Local PDR
label Local PDR
voice register dn  52
number 166
name Mohamed Hantous
label Mohamed Hantous
voice register dn  53
number 170
name Anouar Souli (Bloc G)
label Anouar Souli (Bloc G)
voice register dn  55
number 167
voice register template  1
dialplan 1
voice register dialplan 1
type 7940-7960-others
pattern 1 0*
voice register pool  1
id mac 5C50.15A9.7C05
type 3905
number 1 dn 53
cor incoming Agent default
codec g711ulaw
voice register pool  2
id mac 5C50.15A9.ACF8
type 3905
number 1 dn 52
codec g711ulaw
voice register pool  3
id mac 5C50.15A8.B072
type 3905
number 1 dn 49
codec g711ulaw
voice register pool  4
id mac 5C50.15A9.04F1
type 3905
number 1 dn 45
codec g711ulaw
voice register pool  5
id mac 5C50.15A9.AD2D
type 3905
number 1 dn 44
codec g711ulaw
voice register pool  6
id mac 5C50.15A9.ABC5
type 3905
number 1 dn 51
codec g711ulaw
voice register pool  7
id mac 5C50.15A8.ABAB
type 3905
number 1 dn 50
codec g711ulaw
voice register pool  8
id mac 5C50.15A9.7C51
type 3905
number 1 dn 46
codec g711ulaw
voice register pool  9
id mac 5C50.15A9.AC54
type 3905
number 1 dn 47
codec g711ulaw
voice register pool  10
id mac 5C50.15A9.AC3C
type 3905
number 1 dn 48
codec g711ulaw
voice register pool  11
id mac 5C50.15A9.0561
type 3905
number 1 dn 43
codec g711ulaw
voice register pool  12
id mac 5C50.15A8.AE1F
type 3905
number 1 dn 37
codec g711ulaw
voice register pool  13
id mac 5C50.15A8.AF96
type 3905
number 1 dn 36
cor incoming Cadre default
codec g711ulaw
voice register pool  14
id mac 5C50.15A8.AC62
type 3905
number 1 dn 35
codec g711ulaw
voice register pool  15
id mac 5C50.15A9.7AE1
type 3905
number 1 dn 34
codec g711ulaw
voice register pool  16
id mac 5C50.15A9.7AB2
type 3905
number 1 dn 41
codec g711ulaw
voice register pool  17
id mac 5C50.15A8.ABCE
type 3905
number 1 dn 42
codec g711ulaw
voice register pool  18
id mac 5C50.15A8.B273
type 3905
number 1 dn 39
codec g711ulaw
voice register pool  19
id mac 5C50.15A9.0624
type 3905
number 1 dn 40
codec g711ulaw
voice register pool  20
id mac 5C50.15A9.7DA1
type 3905
number 1 dn 38
codec g711ulaw
voice register pool  21
id mac 5C50.15A8.AF55
type 3905
number 1 dn 28
codec g711ulaw
voice register pool  22
id mac 5C50.15A9.7D73
type 3905
number 1 dn 27
codec g711ulaw
voice register pool  23
id mac 5C50.15A9.0556
type 3905
number 1 dn 26
codec g711ulaw
voice register pool  24
id mac 5C50.15A9.7D0D
type 3905
number 1 dn 25
codec g711ulaw
voice register pool  25
id mac 5C50.15A9.7C06
type 3905
number 1 dn 24
cor incoming Directeur2 default
codec g711ulaw
voice register pool  26
id mac 5C50.15A9.ACFB
type 3905
number 1 dn 33
codec g711ulaw
voice register pool  27
id mac 5C50.15A8.A9B9
type 3905
number 1 dn 32
codec g711ulaw
voice register pool  28
id mac 5C50.15A8.A86D
type 3905
number 1 dn 30
codec g711ulaw
voice register pool  29
id mac 5C50.15A8.A8C7
type 3905
number 1 dn 29
codec g711ulaw
voice register pool  30
id mac 5C50.15A9.7D74
type 3905
number 1 dn 31
codec g711ulaw
voice register pool  31
id mac 5C50.15A9.7D51
type 3905
number 1 dn 19
codec g711ulaw
voice register pool  32
id mac 5C50.15A8.B2B6
type 3905
number 1 dn 20
codec g711ulaw
voice register pool  33
id mac 5C50.15A8.AFB7
type 3905
number 1 dn 21
codec g711ulaw
voice register pool  34
id mac 5C50.15A9.0601
type 3905
number 1 dn 22
codec g711ulaw
voice register pool  35
id mac 5C50.15A8.ABB2
type 3905
number 1 dn 23
codec g711ulaw
voice register pool  36
id mac 5C50.15A9.0626
type 3905
number 1 dn 15
codec g711ulaw
voice register pool  37
id mac 5C50.15A9.0890
type 3905
number 1 dn 14
codec g711ulaw
voice register pool  38
id mac 5C50.15A8.A8CE
type 3905
number 1 dn 16
template 1
dtmf-relay sip-notify
codec g711ulaw
voice register pool  39
id mac 5C50.15A8.B09D
type 3905
number 1 dn 17
codec g711ulaw
voice register pool  40
id mac 5C50.15A8.B061
type 3905
number 1 dn 18
codec g711ulaw
voice register pool  41
id mac 5C50.15A9.05DB
type 3905
number 1 dn 8
codec g711ulaw
voice register pool  42
id mac 5C50.15A8.AFC4
type 3905
number 1 dn 12
codec g711ulaw
voice register pool  43
id mac 5C50.15A9.0741
type 3905
number 1 dn 10
codec g711ulaw
voice register pool  44
id mac 5C50.15A9.7ADE
type 3905
number 1 dn 3
codec g711ulaw
voice register pool  45
id mac 5C50.15A9.775A
type 3905
number 1 dn 2
codec g711ulaw
voice register pool  46
id mac 5C50.15A9.AB36
type 3905
number 1 dn 13
codec g711ulaw
voice register pool  47
id mac 5C50.15A8.39DE
type 3905
number 1 dn 11
cor incoming Cadre2 default
codec g711ulaw
voice register pool  48
id mac 5C50.15A8.ADCB
type 3905
number 1 dn 9
codec g711ulaw
voice register pool  49
id mac 5C50.15A8.ACAF
type 3905
number 1 dn 5
codec g711ulaw
voice register pool  50
id mac 5C50.15A8.AC79
type 3905
number 1 dn 7
codec g711ulaw
voice register pool  51
busy-trigger-per-button 1
id mac 442B.0319.BECF
type 6921
number 1 dn 4
codec g711ulaw
voice translation-rule 1
rule 1 /^0/ //
voice translation-profile International
translate called 1
license udi pid CISCO2921/K9 sn FCZ16302022
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 150
ip address 10.16.150.253 255.255.255.0
interface GigabitEthernet0/2
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
tftp-server flash:APP3905.9-2-1-0.zz
tftp-server flash:CP3905.9-2-1-0.loads
tftp-server flash:apps31.9-3-1TH2-5.sbn
tftp-server flash:cnu31.9-3-1TH2-5.sbn
tftp-server flash:cvm31sip.9-3-1TH2-5.sbn
tftp-server flash:dsp31.9-3-1TH2-5.sbn
tftp-server flash:jar31sip.9-3-1TH2-5.sbn
tftp-server flash:SIP31.9-3-1-1S.loads
tftp-server flash:term31.default.loads
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-11-124120.zz.sgn
tftp-server flash:SIP69xx.9-3-1-5.loads
tftp-server flash:SIP69xx.9-3-1-5.zz.sgn
tftp-server flash:rtl-sccp.jar alias SIP_French_France/rtl-sccp.jar
tftp-server flash:g3-tones.xml alias SIP_France/g3-tones.xml
tftp-server flash:cin-sip.jar alias SIP_French_France/cin-sip.jar
tftp-server flash:g3-tones.xml alias France/g3-tones.xml
tftp-server flash:gp-sccp.jar alias French_France/gp-sccp.jar
control-plane
voice-port 0/1/0
trunk-group PSTN
voice-port 0/1/1
trunk-group PSTN
shutdown
voice-port 0/1/2
trunk-group PSTN
shutdown
voice-port 0/1/3
trunk-group PSTN2
connection plar opx immediate 100
voice-port 0/2/0
trunk-group PSTN2
shutdown
voice-port 0/2/1
trunk-group PSTN2
shutdown
voice-port 0/2/2
trunk-group PSTN2
shutdown
voice-port 0/2/3
trunk-group PSTN2
shutdown
voice-port 0/3/0
shutdown
voice-port 0/3/1
shutdown
voice-port 0/3/2
shutdown
voice-port 0/3/3
shutdown
mgcp profile default
gatekeeper
shutdown
telephony-service
max-ephones 20
max-dn 30
ip source-address 10.16.150.253 port 2000
user-locale FR
network-locale FR
max-conferences 16 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 06 2013 16:07:37
ephone-dn  1  dual-line
number 100
label Standard
name Standard
corlist incoming Standard2
ephone-dn  2  dual-line
number 200
label Standard
name Standard
ephone-dn  3  dual-line
number 300
label Standard
name Standard
ephone-dn  4  dual-line
number 400
label Standard
name Standard
ephone-dn  5  dual-line
number 500
label Standard
name Standard
ephone-dn  6  dual-line
number 600
label Standard
name Standa
ephone  1
mac-address 0004.F2F2.D4DC
button  1:1
ephone  2
mac-address 0C85.253E.AC3C
button  1:1 2:2 3:3 4:4
button  5:5 6:6
ephone-hunt 1 sequential
pilot 888
list 100, 200, 300, 400, 500, 600
paolo bevilacqua
Wrong forum, post in "IP telephony". You can move your post using the actions panel on the right.
