Cp 8111 bluetooth transmitter
lars meier
hello
I have a question:
i work in my home office with the cisco cp8811 phone, this phone has no bluetooth.
question is there an adapater to retrofit so that the cp8811 can be used with bluetooth headphones?
where? please send link
thank you
5 Replies 5
lpersing
Hello, I looked up the spec sheet and the 8811 does not have a USB port for a Bluetooth dongle. So you are most likely limited to a wired headset.
lpersing
If you are looking to upgrade the 8851, 8861 and 8865 lall have USB ports that can accept a USB Bluetooth dongle. HTH
Are sure that the 8811 have a usb port ? It doesn’t look so
The 8811 does not have a USB port.
Jonathan Schulenberg
Wireless headsets with only RJ9 headset +. AUX jacks are traditionally DECT with a base station and Electronic Hookswitch (EHS) cable - which is phone OEM specific, so be careful. The Jabra Engage 75 is an example.
https://www.jabra.com/business/office-headsets/jabra-engage/jabra-engage-75##9556-583-125
