CP 8831 without CUCM??
odufour01
Hi, I'm relatively new to IP telephony, and a just bought a Cisco 8831 Ip Conference phone to complete our actual SPA 504g system of 8 units.
I don't use CUCM, so i was planning to configure 8831 as a standalone unit, with it's own registering configuration, as i did with our other phones. But i realize i have no access to any configuration page, and everything i read on the web points me to the Call Manager software. Do i really need to use it? Is there any way to configure the phone as a standalone unit? I don't want to buy a software just to configure one phone...
Your explanations and advices would really help!
Thank you.
Olivier
Anas Abueideh
Level 9
Level 9
You need call manager or call manager express to use this phone. you can't use it standalone
kindly check the below data sheet
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/data_sheet_c78-726887.html
Anas
don't forget to rate the helpful posts
Thank you Anas for your answer. We are in a Macintosh environment, and we don't use any local server since all our shared files are on Dropbox and GoogleDrive. So, in this case, i suppose i have no option than trying to sell my 8831 and try to find an other standalone model?
Is there any way to use Cm Express locally on a pc and use it to "push" configuration to the phone without having to set a permanent server?
Again, thank you so much for your help.
Olivier
Hi Oliver,
for CM express you need a voice gateway to configure that. for CUCM you need a virtual machine in VMware over cisco UCS server.
are you looking for stand alone conference audio or video ?
Anas
Hi Anas,
I'm just looking for a good quality ip conference phone for voice only. Maybe i could resell my 8831 on ebay and buy another model... Would you recommend one in particular?
Thank you,
Olivier
