CP 8851 - Convert IP phone to SIP
GlonetCisco
We bought an CP 8811 Phone that we like to convert to sip. I have downloaded the latest zip file. (8811, 8841, 8851, 8851NR and 8861 SIP IP Phone firmware files only - Compatible CUCM Versions: 8.5(1)+
cmterm-88xx.11-0-1-11.zip ) I copied the files to my tftp server. After rebooting the phone it stays on "phone is registering"
I adjust the tftp setting in my dhcp to my asterisk server.
Can someone help me. It's the first we try to convert an IP phone to sip.
As far as I know , 8811 is sip only phone.
Please check here
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731637.html
Carlo
Please rate all helpful posts "The more you help the more you learn"
6 Replies 6
Please check here
Carlo
Hello Carlo,
Thank you for the answser. when we startup the phone we have to sign in with a service domain, username and password? I want to register the phone in my asterisk.
Glonet
Hi Glonet,
use the following link as starting point.
Here you can find different config samples to help you registering 8811 with a soft switch like Asterisk.
http://pbxinaflash.com/community/threads/cisco-8800-phones.17114/
Carlo
Ok thanks for the help. I made a xml file but my phone stucks on unprovisend. First of all i want to upgrade my phone to the latest firmware. I unpacked the folder cp-88xx-sip.10-3-1-9-3PCC and dropped the files in the tftp folder on my asterisk with full rights. when i reboot my phone it stays on "phone is registering"
can you resolve this problem because same error.
Create a new thread and don't re-hash this one (it will confuse others).
Put as much relevant information as you can.
