IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5507 Views
  • 14 replies
Hello, We are running Call Manager 10.5.2.12901-1 and every often we keep getting "Number of Registered Gateways Decreased" alerts from the RTMT. I looked through the application logs in syslog viewer to locate the cause of this and I saw a critical ...
Guys i need your help urgently  i am posting  my  voice Translation  rules as per ISP sent me please tell me if it's correct  *Regarding Numbering Format, use the following:• For outgoing Calls : The originating Number (A#), should be 96613510XXXX f...
Hi All. One of our customer has 3825 VG with PVDM2-64 with VWIC2-2MFT-T1/E1 and was using only one E1 PRI, now customer requested to add another E1 PRI on this VG, when trying to add/confirgure, router was throwing DSP resource error, so I shutdown c...
! dial-peer cor list user-local  member international-fac  member local  member toll ! dial-peer cor list call-international-fac  member international-fac ! ephone-dn  98  octo-line  corlist incoming user-local ! FXO Port à Outgoing Call Works with F...
faiqmahdi by Level 1
  • 206 Views
  • 0 replies
Requirement is - User who wants to join a meet-me conference should be authenticated before allowing him into the conference I have searched extensively for this in the internet and found that there are two methods in connecting to a meet me conferen...
majeed002 by Level 1
  • 665 Views
  • 1 replies
