11-23-2015 09:03 AM - edited 03-18-2019 11:42 AM
All,
is there a way to create an OS Admin level account other than the one that was created during the system install? If so then how do I go about it?
Thanks in advance! Replies rated
Solved! Go to Solution.
11-23-2015 09:13 AM
11-23-2015 09:13 AM
11-23-2015 09:23 AM
(+5) to Jaime
11-23-2015 11:26 AM
I am entering "set account name manager" and getting an errors stating the command was not successfully completed. Any reason this might be working? V10.5
11-23-2015 11:32 AM
Try with something else, instead of manager, that might be the problem (there are some keywords the system won't let you use), and are you runnig the command when logged in with the built-in OS admin??
11-23-2015 11:45 AM
I tried several differen names. I think the issues is as you asked. The account I was using to create the new accounts is not the built in OS Admin account. It was created by someone with that account and the person with the built in OS account doesn't seem to want to give that account up
