create reports on phone calls
wstemmons1984
I'm trying to use the CUCM CDR Analysis and Reporting. I want to create a report that will show calls to an extension. The report should show the number of calls to that extension, the average duration, and the number of missed calls. This also includes Hunt Pilots. I haven't found a way to customize a report to what I'd like. Any suggestions?
I have a list here, you'd need to reach out to the vendors to find out which best suits your needs.
http://docwiki.cisco.com/wiki/CUCM_FAQ#What_3rd_party_Billing_Servers_can_I_use_with_CUCM.3F.3F
java
if this helps, please rate
Jaime Valencia
CAR only provides canned reports that you cannot customize, if they do not fit your needs, you'd need to buy a 3rd party billing app, or to build your own app to process the CDR flat files and get the info.
java
Thank you Jamie for responding to my question. You have verified my findings when reading the documentation on CDR. Do you have any suggestions on a 3rd party application that work for me?
java
