Hi all,
I have a question about payload capability.
CUCM 10.5, when I look at calls in CDR records, some calls have payload capability of 303.
MediaTransportAdd_Ip |
10.162.128.133 |
10.101.0.20 |
PayLoadCapability |
2 |
303 |
As it states in documents, CDR fields origMediaCap_payloadCapability and destMediaCap_payloadCapability are used to define what codec originator and destination uses.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdradmin/cdrfdes.html
Also, here is the document with explanation of codes - https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdradmin/cdrcodes.html#wpxref71071
In my case, both are fax machines (originator and destination).
Capability of 2 means g711alaw (64k).
What is 303?
Can it be Mobility HandIn (although, it is not codec, but disconnect reason)?
Thx to all,
Kristijan
