creating report for users full name extension and external calling mask
sprintership-il
Experts,
i am using CCUM 10.X and wonder how can I generate report including users full name extension and external calling mask
Thank You,
dwayne rattan
Have you looked at CDR reporting on the servicability page as yet.
Follow the following to enable it under enterprise parameters:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_6_1/car/car/caranrpt.html
The reports are not very detailed and can be exported as CSV or PDF. You can can use Imagicle Billy Blues if you want a more detailed report.
Thank You dwaye but I am  looking for something more easier like first last name + extension and external phone number
There is no native reporting to give you that, at best, you'll get the userID if it's associated to the device (on one report), you'd need to map two reports, or do this via SQL query on CLI
java
if this helps, please rate
Jitender Bhandari
Try below and let me know if it helps
run sql select label, display, e164mask from devicenumplanmap
OR
run sql select label, displayascii, e164mask from devicenumplanmap
JB
