CSF Device Desktop Client Settings
Paul McGurn
Level 6
Level 6
Is there any documentation on what all these do?
I know what Cisco Support Field does, but what is the analytics-related stuff for?
Jaime Valencia
Hit the big Yellow/orange question mark under product specific configuration layout.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
unfortunately it doesn't help much.  The description for the two analytics settings barely qualifies as "documentation", vs. just "a longer way to describe this setting without indicating what it does".
Indicates if analytics collection is enabled or disabled for the client.
   This is a required field.
   Default:                  Disabled
The URL of the analytics server that will be used by the client. The default is blank.
   Maximum length:                1024
What analytics are collected?  What type of URL/service is it hitting?
I agree, still haven't found a use for these settings.
Anything more Cisco can add?
