CTI route point to transcode to use g729 toTCL app
Hi I had made a tcl app and now I need to other sites call that tcl app..
As far as I now g729 is not supported by tcl and as documentation says TCL will not able to invoke any transcode resource..
So my idea is to create a CTI route point and configure a cfw all to a route pattern that points to the site b gw...
phone site A (DP_A) ---> CTI route point  (DP_RP)---> Route Pattern ---> GW site B  (DP_B)
Region Site A                          Region RP                                                       Region site B
On SITE A Region config:
max g729 to siteB
max g711 to siteA
The idea is that every call from phones from site A to siteB phones would be with g729
But calls to the CTI route point will be on g729 the a cfwa to the route pattern that point to site B GW that  has a dial-peer that only permits G711
, so the route point will invoke the transcoding resource..
Is this  even possible??? Will the CTI Route Point invoke the transcoding resource??
As far as I could see phone A its negotiation directly with GW from site B the codec regardless the configuration I made on the CTI route point Region assigned to its DP.
Gateway is h323
Lisandro
I had also try a trunk sip and the codec configuration works great but then I am getting an error while transfering back to cucm I guess because one leg its sip and the other its h323.
When I call the TCL IVR from sitea then dial option 1.. that send the call to a phone on site B and the phone on siteB answer the call but phone on siteA continue ringing and do not notice that the other side has answered the call...
(allow connection h323 SIP/ SIP h323 also configured)
thanks
Lisandro
