CTS video through Cube to 9971 doesn't work well.
gilbert spoor
I am running a Lab with two CUCM8.6.2 environments and a router acting as CUBE in between.
In one environment I have a video SIP phone (Cisco E20) and a cts-1100 running software 1.9.
in the other environment I have an E20 and a Cisco 9971 video enabled phone.
a cisco 2921 router is configured for the CUBE functionality.
I can call between the two environments without any problem using the E20's audio and video gets relayed by the cube.
But when calling between the CTS-1100 and the E20 or the 9971 in the other environmkent doesn't work well, the E20 doesn't receive video or audio and remains in an answering state, while the CTS receives audio and video from the e20 through the cube (so one way media)
when the CTS calls the E20 that is registered to the same callmanager audio and video work fine.
does anyone know what I'm doing wrong?
Below the config of the router:
version 15.0
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
ip source-route
ip cef
vlan ifdescr detail
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
rtp-ssrc multiplex
address-hiding
allow-connections sip to sip
redirect ip2ip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  session transport tcp
  rel1xx disable
  header-passing sip-sip
  midcall-signaling passthru
  g729 annexb-all
  pass-thru content sdp
voice class codec 1
codec preference 1 aacld
codec preference 2 g711alaw
codec preference 3 g711ulaw
codec preference 4 g722-64
codec preference 5 g728
hw-module pvdm 0/0
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface GigabitEthernet0/0
ip address 192.168.222.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.1.1.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.2.2.254 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 192.168.255.0 255.255.255.0 192.168.222.254
control-plane
codec profile 1 aacld
codec profile 2 h264
codec profile 3 h263+
codec profile 4 h263
dial-peer voice 1 voip
description cucm1
destination-pattern 1...
rtp payload-type cisco-codec-video-h264 112
session protocol sipv2
session target ipv4:10.1.1.1
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2 voip
description cucm2
destination-pattern 3...
session target ipv4:10.2.2.1
voice-class codec 1
dtmf-relay rtp-nte
sip-ua
no remote-party-id
retry invite 2
gatekeeper
shutdown
keglass
Level 7
Level 7
Gilbert,
This community does not provide technical support and is not staffed with technical support experts. I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) where our Cisco technical support experts provide assistance. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert assistance.
We do encourage you to participate in the Cisco Collaboration Community and to also join our Cisco Collaboration User Group program!  In the community, we encourage your discussion/sharing around collaboration topics and Cisco Collaboration Solutions, including business and IT requirements, industry trends, process, culture/organization issues, how collaboration can be used to transform businesses, vendor selection, adoption, training, architecture, licensing, and product features/functionality. If you are a customer or partner, you can also join the user group program to be eligible for member-only events and influence product direction.
We hope to hear from you again.
Kelli Glass
Moderator for the Cisco Collaboration Community
I was told by our Cisco SE to post the question here.
This was supposed to be the place where all the telepresence specialists would meet.
what kind of discussions should take place here then? all non technical stuff?
I can understand the confusion as there are a number of discussion spaces within Cisco. As described on the Telepresence Space home page in the Collaboration Community, this space is mainly for discussion purposes between community members and Cisco Telepresence Solutions experts:
Join visitors within the Cisco Collaboration Community in discussing Cisco TelePresence uses, technology, architecture, products, customer case studies and more. Share useful Cisco TelePresence resources. Note: For IT installation, implementation and debugging questions, visit the Cisco Support Community (formerly NetPro) and Cisco.com support area.
According to your post, you are experiencing technical difficulties, which is best addressed in the Cisco Support Community (under Telepresence, specifically).
I hope that helps answer your question. Thank you for participating in the Community!
Kelli Glass
