CUBAC error code 5007
virhilario
Hi:
I´m having problems syncronizing with CUCM, I create an application user called CUBAC, I assigned to that user the group I create with certain roles that the guide says (including de AXL API Access role), also the Standard CCM Super User Group.
I go to the CUCM connectivity menu ( where the CUBAC user is to have communiction with CUCM)  click on TEST CONNECTION, and get CUCM test connection succeded!!
I uncheked the box for User Acount Control on the Windows 2008 server where the CUBAC software is.
Any idea about the error I´m getting??
CUBAC               error code 5007                     Item not valid: The specified User was not found
virhilario
Ok I just resolved the problem. Thanks anyways!!!
Viridiana,
I have the same problem. How do they solved?
I didn´t read carefully, in the manual says " END APPLICATION USER"  not APPLICATION USER. So creat an END USER for CUBAC.
If helped pls rate it
