05-26-2015 03:30 PM - edited 03-17-2019 03:08 AM
i have CUBE configuration and it is connected with ITSP.
now ITSP wants to send g729r8 codec when call goes from CUCM. see CUBE configuration:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.05.27 01:27:31 =~=~=~=~=~=~=~=~=~=~=~=
Building configuration...
Current configuration : 12136 bytes
! Last configuration change at 01:22:02 AST Wed May 27 2015 by admin
! NVRAM config last updated at 01:22:58 AST Wed May 27 2015 by admin
version 15.2
hostname CUBE-B
boot-start-marker
boot-end-marker
no logging queue-limit
no logging rate-limit
aaa new-model
--More-- aaa authentication login AAA-VPN local
aaa authorization network AAA-VPN local
aaa session-id common
clock timezone AST 3 0
clock calendar-valid
ip cef
ip dhcp excluded-address 10.100.107.254 10.100.107.255
ip dhcp excluded-address 10.100.106.1 10.100.106.15
ip dhcp excluded-address 10.100.106.254 10.100.106.255
ip dhcp excluded-address 10.100.105.1 10.100.105.15
ip dhcp excluded-address 10.100.105.254 10.100.105.255
ip dhcp excluded-address 10.100.107.1 10.100.107.15
ip dhcp pool IP Phones
--More-- network 10.100.107.0 255.255.255.0
default-router 10.100.107.1
option 150 ip 10.100.106.7 10.100.106.8
ip dhcp pool Data
network 10.100.105.0 255.255.255.0
default-router 10.100.105.1
dns-server 8.8.8.8 8.8.4.4
ip domain name vodafone.qa
ip host vodafone.qa 172.16.9.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
--More-- !
crypto pki trustpoint TP-self-signed-1241508841
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1241508841
revocation-check none
rsakeypair TP-self-signed-1241508841
crypto pki certificate chain TP-self-signed-1241508841
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31323431 35303838 3431301E 170D3134 30313233 31313230
34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32343135
30383834 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100F17F 77654DC5 6E11ACA8 D87C3B5F 053AF681 4AFC9366 937D07CA 2992DCA5
69C62457 A5FF85F6 CEAC5005 39F5FC5B 8BD041A5 CF4F7790 8C22B70A C8AD3E24
BE40FC12 6949818B 6540EAFA BA25BBC1 587DC548 9F9D39D2 5C09190A 8FF37461
AC5B0773 CE6F4A40 CD24E39B BFDE5D5E 76870778 62D77460 46FE4BFC 8C5726FA
A3DD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 145DCC3D A3769852 593EE270 50E81FEC 5424BE5C 78301D06
03551D0E 04160414 5DCC3DA3 76985259 3EE27050 E81FEC54 24BE5C78 300D0609
--More-- 2A864886 F70D0101 05050003 8181002E 10F78D93 6CB5AC71 5FC245A4 1EA22D0A
9E5DBBA4 DEE1575E 316689D5 AAFC7DE8 71F6C2EC 5AC89AB3 C3063469 53F67E20
1026A8FF 7A0B59A5 032556CE 9C697C83 6C982706 D8F5576A A1DE7F8C EDF7C0EE
9136608E 7E1287C7 948A1EA9 F19D828B 9628EE01 CEDEB69B C8F78EC8 BCAF73A9
F202D03E EDF9A91A 2DE12497 A42B13
quit
voice-card 0
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
ipv4 0.0.0.0
mode border-element license capacity 100
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
rel1xx disable
header-passing
error-passthru
no update-callerid
bearer-capability clear-channel rdi
--More-- early-offer forced
midcall-signaling passthru
g729 annexb-all
sip-profiles 400
voice class codec 4
codec preference 1 g729br8
codec preference 2 g711ulaw
voice class sip-profiles 400
request INVITE sip-header Diversion modify "sip:(.*>)" "sip:+97440002300@vodafone.qa>"
request REINVITE sip-header Diversion modify "sip:(.*>)" "sip:+97440002300@vodafone.qa>"
request INVITE sip-header From modify "<sip:(.*)@(.*)>" "<sip:\1@vodafone.qa>"
request INVITE sip-header Diversion modify "sip:(.*>)" "sip:+97440002330@vodafone.qa>"
request REINVITE sip-header Diversion modify "sip:(.*>)" "sip:+97440002330@vodafone.qa>"
--More-- voice translation-rule 2
rule 1 /^9\(.*\)/ /\1/ type any national plan any isdn
voice translation-profile QE-out
translate called 2
license udi pid CISCO2911/K9 sn FCZ17276032
hw-module pvdm 0/0
username admin privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
username vodafone password 0 v367897
redundancy
--More-- !
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group vpnall
key gb34567
dns 8.8.8.8
pool VPNALLPOOL
crypto isakmp client configuration group vodafone
key voda67890
dns 8.8.8.8
pool VPNALLPOOL
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
mode tunnel
--More-- crypto dynamic-map dynmap 10
set transform-set 3des-sha
crypto map vpn client authentication list AAA-VPN
crypto map vpn isakmp authorization list AAA-VPN
crypto map vpn client configuration address respond
crypto map vpn 10 ipsec-isakmp dynamic dynmap
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.50
--More-- encapsulation dot1Q 50
ip address 10.100.105.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0.60
encapsulation dot1Q 60
ip address 10.100.106.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.70
encapsulation dot1Q 70
ip address 10.100.107.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
description Alcatel Router pointing interface
ip address 10.72.0.66 255.255.255.248
ip access-group RESTRICT-VODAFONE in
ip nat outside
--More-- duplex auto
speed auto
interface GigabitEthernet0/2
description internet
ip address 80.76.165.118 255.255.255.252
ip access-group RESTRICT-INTERNET in
ip nat outside
duplex auto
speed auto
crypto map vpn
ip local pool VPNALLPOOL 10.100.109.1 10.100.109.254
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool INTERNET 80.76.165.118 80.76.165.118 netmask 255.255.255.252
ip nat inside source list NAT-ACL interface GigabitEthernet0/2 overload
--More-- ip route 0.0.0.0 0.0.0.0 80.76.165.117
ip route 172.16.9.4 255.255.255.255 10.72.0.65
ip access-list extended NAT-ACL
deny ip 10.100.105.0 0.0.0.255 10.100.109.0 0.0.0.255
deny ip 10.100.106.0 0.0.0.255 10.100.109.0 0.0.0.255
deny ip 10.100.107.0 0.0.0.255 10.100.109.0 0.0.0.255
permit ip 10.100.105.0 0.0.0.255 any
permit ip 10.100.106.0 0.0.0.255 any
permit ip 10.100.107.0 0.0.0.255 any
ip access-list extended RESTRICT-INTERNET
deny udp any any eq 5060
deny tcp any any eq 5061
deny udp any any eq 5061
deny tcp any any eq 5060
deny tcp any any eq telnet
deny tcp any any eq www
deny icmp any any echo
deny tcp any any eq 22
deny tcp any any eq 1720
deny tcp any any eq 1719
permit ip any any
permit esp any any
--More-- ip access-list extended RESTRICT-VODAFONE
deny tcp any any eq echo
permit ip any any
ip access-list extended SPLIT-TUNNEL-ACL
permit ip 10.100.109.0 0.0.0.255 10.100.105.0 0.0.0.255
permit ip 10.100.109.0 0.0.0.255 10.100.106.0 0.0.0.255
permit ip 10.100.109.0 0.0.0.255 10.100.107.0 0.0.0.255
ip access-list extended VPNACL_REMOTE
permit ip 10.100.109.0 0.0.0.255 any
access-list 2 permit 10.100.105.0 0.0.0.255
access-list 2 permit 10.100.106.0 0.0.0.255
access-list 2 permit 10.100.107.0 0.0.0.255
control-plane
--More-- !
mgcp profile default
dial-peer voice 100 voip
description ** INBOUND LAN SIDE DIAL_PEER FROM CUCM TO CUBE **
session protocol sipv2
session target sip-server
incoming called-number 9T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 200 voip
description ** OUTBOUND LAN SIDE DIAL_PEER FROM CUBE TO CUCM **
preference 1
destination-pattern +9744000....$
--More-- session target ipv4:10.100.106.7:5060
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 201 voip
description ** OUTBOUND LAN SIDE DIAL_PEER FROM CUBE TO CUCM 2 **
preference 2
session target ipv4:10.100.106.8:5060
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 1000 voip
description ** INBOUND WAN SIDE DIAL_PEER FROM SP TO CUBE **
incoming called-number +9744000....$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3000 voip
description *** LOCAL DIALING POOL WAN-SIDE DIAL_PEER ***
--More-- translation-profile outgoing QE-out
destination-pattern 9[4].......$
voice-class sip profiles 400
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2000 voip
description *** MOBILE DIALING POOL WAN-SIDE DIAL_PEER ***
destination-pattern 9[3567].......$
voice-class codec 4
dtmf-relay rtp-nte
dial-peer voice 4000 voip
--More-- description *** EMERGENCY DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 999$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5000 voip
description *** INTERNATIONAL DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 900T
dtmf-relay rtp-nte
codec g711ulaw
--More-- dial-peer voice 5001 voip
destination-pattern 900#T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 6000 voip
description *** SPECIAL LOCAL DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 9[28]......$
dtmf-relay rtp-nte
codec g711ulaw
--More-- !
dial-peer voice 7000 voip
description *** SHORT DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 91..$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 1 voip
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
gateway
timer receive-rtp 1200
--More-- sip-ua
sip-server dns:vodafone.qa:5061
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input telnet ssh
--More-- line vty 5 15
exec-timeout 0 0
privilege level 15
scheduler allocate 20000 1000
ntp master
ntp server pool.ntp.org
end
CUCM region is g711ulaw so that when i calls out or incoming call, it shows g711ulaw codec to us.
Telephony call-legs: 0
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
0 : 19765 1079700530ms.1 (01:28:37.808 AST Wed May 27 2015) +6530 pid:100 Answer +97440002335 active
dur 00:00:25 tx:1433/229280 rx:1432/229120 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 10.100.106.7:27966 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
0 : 19766 1079700530ms.2 (01:28:37.808 AST Wed May 27 2015) +6520 pid:2000 Originate 66774169 active
dur 00:00:25 tx:1432/229120 rx:1579/252640 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 172.16.9.4:29328 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
how can we apply g729 for incoming and outgoing calls?
as we have the UCCX and call recording is configured so would be affect this change?
06-06-2015 07:50 PM
did you change in CUCM the CUBE Region to G.729?
Regards.
