CUBE Inbound call to Pilot
SHQ
Hello
I'm having issue configuring CUBE running IOS 15.2(4)M3 with an ITSP, incoming calls are landing on Pilot no.
The ITSP is sending INVITE with Username in the Request-URI, need to replace it with the To field.
dial-peer voice 100 voip (to ITSP)
destination-pattern .T
session protocol sipv2
session target ipv4:10.0.1.1
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 101 voip (from ITSP)
incoming called-number .T
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 102 voip (to CUCM)
destination-pattern 445566..
session target ipv4:172.16.1.195
voice-class codec 1
dtmf-relay sip-notify
dial-peer voice 103 voip (from CUCM)
voice-class codec 1
Please let me know on which dial-peer to apply the sip-profile commands. I had tried some, but didnt work.
12 Replies 12
Use the command 'debug voice dialpeer' to find which dialpeer is matched for inbound then apply the sip-profile to it. Because you are applying it on inbound dialpeer you need to enable this feature.
voice service voip
 sip
 sip-profiles inbound
Hello
It's giving the below error, when i try to enable inbound. If its not supported, is there any other way to copy, for incoming call SIP To header to Request-URI for calls from ITSP to CUCM
SIP(config)#voice service voip
SIP(conf-voi-serv)#sip
SIP(conf-serv-sip)# sip-profiles inbound
% Invalid input detected at '^' marker.
SIP(conf-serv-sip)# sip-profiles ?
  <1-10000>  The sip profiles tag number to be linked as global
SIP(conf-serv-sip)# sip-profiles 101 ?
<cr>
Ops. I am sorry I just saw that you are on IOS 15.2(4) which doesn't
support this feature. Its supported on Cisco IOS 15.4(2)T Cisco IOS XE
3.12S.
The easiest option is to upgrade (there are lot of new nice features in
newer versions for CUBE). You can do some work with corlists to get it
working but you have to create multiple duplicate dialpeers.
Hello
UPDATE:
I have upgraded to 15.7(3)M
Have  managed to apply the sip-profiles, incoming is working fine, but when external party disconnects the call, it doesnt disconnect on CUCM End. Attached debug
voice service voip
 ip address trusted list
 ipv4 172.16.1.195
 ipv4 10.0.1.46
 ipv4 10.0.1.1
 address-hiding
 mode border-element license capacity 30
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
  sip
   rel1xx require "100rel"
   header-passing
   asserted-id pai
   midcall-signaling passthru
   privacy-policy passthru
   pass-thru content sdp
   no call service stop
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice class sip-profiles 1
 request INVITE sip-header P-Asserted-Identity remove
 request INVITE sip-header P-Preferred-Identity add "P-Preferred-Identity: <sip:44556600@10.0.1.1>"
voice class sip-profiles 2
request INVITE peer-header sip TO copy "sip:(.*)@" u01
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
voice class sip-copylist 1
sip-header TO
voice-class codec 1
voice-class sip profiles 1
dtmf-relay rtp-nte
voice-class codec 1
dtmf-relay rtp-nte
voice-class codec 1
voice-class codec 1
Hello
Don't get it, the sip profile 2, as per this link https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/118825-technote-sip-00.html
should give me an output (invite towards CUCM), of request-uri  copied from the TO field (from ITSP invite), but TO field (in invite towards CUCM) is still Pilot number.
Require invite coming from ITSP with TO field to be copied to RURI and TO fields in the invite towards CUCM.
Please help.
From debugs I see cube sent cancel to CUCM and CUCM acknowledge it. Is the call still connected after the external party drops the call.
Yes, its still connected.
Yes, its still connected, keeps ringing.
In CUCM, in the SIP profile assigned to your sip trunk, set the option 'SIP Rel1XX Options' to 'Send PRACK for all 1xx messages'
It's already enabled, for outgoing calls i get the PSTN messages:call wait,busy etc.
Shouldn't the Invite message sent towards CUCM contain TO field as
To: <sip:44556630@172.16.1.195> instead of To: <sip:44556600@172.16.1.195>
Hello
Modified the To successfully, but didnt help. Seems the Cancel RURI needs to be copied from To, is that correct?
Modyfing the CANCEL RURI resolved it, Thanks for your help.
