05-12-2020 03:09 AM
If an old CUBE data sheet says what is shown in the attached image, does this mean the 2911 will support 200 SIP trunk sessions with the DRAM specified? Not that 512MB is the minimum DRAM, and 200 is the max SIP trunk sessions possible with whatever the max DRAM the platform is capable of supporting? Thanks.
Solved! Go to Solution.
05-13-2020 07:46 AM
Correct. 200 sessions is the max that the hardware will support. You will not get 400 sessions if you increase DRAM to 1024. However note the ** message at the bottom about decrease in SIP sessions if you are using other session types.
05-13-2020 07:46 AM
