CUBE - Modifying SIP Messages
Simon Battye
Level 2
Level 2
I have a requirement to send SIP 404 Messages to our ITSP for calls "not found" in CUCM.
At the moment this is the call flow:
  • CUCM -> CUBE -> ITSP -> PSTN
If a call comes in from the ITSP, our CUBE queries all CUCM nodes sequentially, each CUCM node returns a 416 Unsupported URI Scheme message if the number is not know to CUCM or is not registered.
Once CUBE has queried all the CUCM nodes, it then sends a 503 Service Unavailable message back to the ITSP but i'd like it to send a 404 Not Found message instead.
Is it possible to use SIP Profiles on CUBE to manipulate/transform these outbound messages to our ITSP?
Thanks, Simon
Jitender Bhandari
Hi Simon,
check the link below it might help.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/118825-technote-sip-00.html
JB
Thanks for this documentation, really useful - I'm hoping the following command will work:
voice class sip-profiles 1
 response 503 sip-header SIP-StatusLine Modify “503 Service Unavailable” “404 Not Found"
I'll test this and confirm if it is OK.
I thinks should take care of it, there was a tool which you would have tested which is not working anymore explained in the link below.
https://supportforums.cisco.com/document/13058446/sip-profile-test-tool
Try i on a dial-peer which is an exact match if you are testing in production so that it does not impact anything else..
JB
