05-18-2017 08:43 AM - edited 03-17-2019 10:22 AM
I have a problem with the RTP stream in a call between multi-vrf on a CUBE (2911)
Here is the config of the CUBE:
--------- VOICE SERVICE VOIP ----------
voice service voip
address-hiding
mode border-element
allow-connections sip to sip
redundancy
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
header-passing
error-passthru
midcall-signaling passthru media-change
early-offer forced
sip-profiles 100
no call service stop
--------- DIAL-PEER INCOMING FROM PSTN (DEFAULT VRF) ----------
dial-peer voice 100 voip
description --- INCOMING VoIP PEER FROM PSTN ---
call-block translation-profile incoming SCAM-BLACKLIST
call-block disconnect-cause incoming call-reject
session protocol sipv2
session transport udp
incoming called-number .
voice-class media 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
--------- DIAL-PEER OUTGOING TO CUCM1 (DEFAULT VRF) ----------
dial-peer voice 201 voip
description --- OUTGOING VoIP PEER TO CUCM ---
destination-pattern <PHONENUMBER1>
session target ipv4:<IP_CUCM1>
voice-class codec 1
no voice-class sip session refresh
voice-class sip bind control source-interface GigabitEthernet0/1.204
voice-class sip bind media source-interface GigabitEthernet0/1.204
dtmf-relay rtp-nte
no vad
--------- DIAL-PEER OUTGOING TO CUCM2 (VRF 1600) ----------
dial-peer voice 1601 voip
destination-pattern <PHONENUMBER2>
session target ipv4:<IP_CUCM2>
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/1.1654
voice-class sip bind media source-interface GigabitEthernet0/1.1654
dtmf-relay rtp-nte
no vad
When dialing from a phone on CUCM1 to a phone on CUCM2 the following RTP is set-up
11 154844 154845 18616 27000 <IP_CUBE_INTERNAL1> <IP_CUCM1> NO CLOUD-0XXX
callId 154844 (dir=1): called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= loopback=NO confID=-1 mode=3 rtp(tx:0/rx:485) rtcp(tx:0/rx:0) MPSS NO VRF CLOUD-0XXX peer callId 154845: called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= , confID:-1
, vrf = CLOUD-0XXX 1 context 0x3FA79BC0 xmitFunc 0x3656BCE0
12 154845 154844 18796 18734 <IP_CUBE_OUTSIDE-VRF(DEFAULT)> <IP_CUBE_OUTSIDE-VRF(DEFAULT)> NO NA
callId 154845 (dir=2): called=<PHONENUMBER2> calling=<PHONENUMBER1>redirect= loopback=NO confID=-1 mode=3 rtp(tx:485/rx:0) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 154844: called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= , confID:-1
, vrf = NA 1 context 0x3FA899E0 xmitFunc 0x3656BCE0
13 154846 154847 18734 18796 <IP_CUBE_OUTSIDE-VRF(DEFAULT)> <IP_CUBE_OUTSIDE-VRF(DEFAULT)> NO NA
callId 154846 (dir=1): called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= loopback=NO confID=-1 mode=3 rtp(tx:513/rx:0) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 154847: called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= , confID:-1
, vrf = NA 1 context 0x3FA2F7C0 xmitFunc 0x3656BCE0
14 154847 154846 18628 27466 <IP_CUBE_INTERNAL2> <IP_CUCM2> NO CLOUD-16XX
callId 154847 (dir=2): called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= loopback=NO confID=-1 mode=3 rtp(tx:0/rx:513) rtcp(tx:0/rx:0) MPSS NO VRF CLOUD-16XX peer callId 154846: called=<PHONENUMBER2> calling=<PHONENUMBER1> redirect= , confID:-1
, vrf = CLOUD-16XX 1 context 0x3D97B740 xmitFunc 0x3656BCE0
So signaling of the call via SIP is working, but when we answer the call, RTP is not routed between the two VRF's (default and 16XX)
Any advice is welcome !!!!!!
