04-06-2016 08:09 AM - edited 03-17-2019 06:29 AM
Is it possible to run CUBE on a CSR1000V to support SIP trunks where the CUBE only has a single interface? (plus its sat behind my Broadband router which isnt very flexible - would I need to use Port Forwarding if NAT isnt supported by SIP Provider?)
Cheers
Rich
05-18-2016 08:57 AM
Did you get an answer to this?
06-10-2016 03:18 AM
No :(
06-14-2016 05:41 AM
06-15-2016 04:08 AM
Cheers. Was this in home lab? what SIP provider did you use? Did you use port forwarding and was it your on your existing internet feed?
I'm keen to get this working on my lab
Rich
