11-27-2011 05:33 AM - edited 03-16-2019 08:15 AM
Hi NetPro´s,
I actually try to configure the new introduced passthrough feature on CUBE.
My idea is to register a 3rd party IP-Phone to a CUCM but with the CUBE as a Border between both, so here´s the call flow:
PhoneA -> CUBE -> CUCM -> PhoneB
The registration itself works fine, PhoneA is registered with the IP-address of the CUBE on CUCM, also calls from CUCM PhoneB to PhoneA (behind the CUBE) work fine.
However I´m not able to make an outgoing call from PhoneA via CUBE via CUCM to PhoneB.
The call (INVITE) get´s stuck in the CUBE and refuses the connection with a "403 Forbidden" message to PhoneA.
I´m not able to find the root cause, why the CUBE refuses the connection... any idea´s??
Many thanks in advance...
Cheers
Torsten
Solved! Go to Solution.
11-27-2011 01:22 PM
Can you please try removing removing the default command "ip address trusted authenticate" as a test:
voice service voip
no ip address trusted authenticate
See whether you get a change in behaviour or not as the case maybe.
11-27-2011 11:24 AM
Hi Torsten,
While checking the logs, Once your Phone B sends the Invite, sip errors are being wriiten like below
*Nov 27 13:05:30.423: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
*Nov 27 13:05:30.427: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Any access list configured ? Can you also paste the successfull incoming call debug messages.
Senthil
11-27-2011 11:57 AM
Hi Senthil,
I think you mean PhoneA, as this is the INVITE which comes to CUBE.. and then the call stucks.
There´re not any access lists configured, nor there´s NAT/PAT in use.
Just for better understanding the IP-network informations here:
network1 192.168.178.0/24
PhoneA .22
network2 172.16.10.0/24
CUBE .1
CUCM .11
network3 172.16.110.0/24
PhoneB .10
The CUBE has a interface Gi0/0 with Sub-Interfaces (0/0.178, 0/0.10, 0/0.110). Gi0/0.10 is binded for SIP usage (172.16.10.1).
I´ll get some traces from the "working scenario" the other way round (so the call from PhoneB via CUCM via CUBE to PhoneA).
Cheers
Torsten.
11-27-2011 01:22 PM
voice service voip
11-27-2011 01:25 PM
Hi Torsten,
Thanks for the information. Do you have incoming dial-peer configured ?
If there is no incoming dial-peer configured, Can we configure one and place the below passthru header in it
voice-class sip pass-thru headers unsupp
After doing this test and check.
Senthil
11-28-2011 04:17 AM
Hi NetworkVoiceOps,
Hi Senthil,
the command "no ip address trusted authenticate" made the difference, after setting the command, the INVITE was forwarded to CUCM (which was the root issue in my case).
Now the INVITE message was send to CUCM, but as response I received a 401 unauthorized and then a 503 Service Unavailable, as the CUBE is not sending any digest authentication to the CUCM.
To solve this issue I added the command "authentication username xxx password yyy realm zzz" under sip-ua and then the 401 unauthorized of CUCM get´s answered with a INVITE with digest authentication..CUCM accept´s the INVITE and call is getting established !
So just to summarize I attached the configuration of the CUBE and the ccsip message trace...
Many thanks to all !!!
Cheers
Torsten.
