CUBE SIP/SDP Modification
Marek Tarnoci
I would like to modify SDP on Cube, that if SDP includes crypto lines but audio/video profile is AVP, change it to SAVP and include the X-cisco-srtp-fallback supported option. I know, that this is possible on CUCM using Normalisation script, also on Cube SP edition using Lua script, but is it possible also on Cube using SIP Profiles? I have Cube connected to Third party Call control, which not allow configuration of Normalisation script.
Hi Marek,
It is possible to modify, add sdp header in cube using sip profiles. For more info please find the below link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/105624-cube-sip-normalization.html
Thanks for the answer, I took a look to the documentation, but seems what I want to do is not possible. (conditional modification)
What I want to achieve is: if INVITE with RTP/AVP and crypto comes in, change RTP/AVP to RTP/SAVP, othervice leave it as it is:
RTP/AVP with crypto lines:
m=audio 3232 RTP/AVP 115 102 9 15 0 8 18 101
a=crypto:1 AES_CM_256_HMAC_SHA1_80 inline:pa3unywt2r03WbHw2rtAh02FUyJjTqpE7V+WGvO0nJkxuWq8KsCddlhYo7RghA==|2^31
a=crypto:2 AES_CM_256_HMAC_SHA1_32 inline:0eX7q06OBEPkMWhV7uJnb5HnQMhb4W6kmdUHxv0/V5nsnReS6Tr0See5dJNmcQ==|2^31
a=crypto:3 AES_CM_128_HMAC_SHA1_80 inline:22lktYUMM9+TV+fw9y3MVGlJiIm0CK1L/Z+5vLlY|2^31
a=crypto:4 AES_CM_128_HMAC_SHA1_32 inline:oDrCVyWGn91tnMe5wBpCRp6oSI+PgWZjb1t4fHH1|2^31
m=application 33183 UDP/BFCP *
a=floorctrl:c-s
a=floorid:1 m-stream:3
a=setup:actpass
a=connection:new
Change RTP/AVP to RTP/SAVP because SDP contains crypto:
m=audio 3232 RTP/SAVP 115 102 9 15 0 8 18 101
a=floorctrl:c-s
a=setup:actpass
a=connection:new
Marek,
This might be possible with the CUBe normalization scrip but if you have something specific to m=audio line when crypto is there.
So for example let's say every time SDP has crypto it will also have 115 in m=audio line.
In that case you could use example script like:
request INVITE sdp-header Audio-Media modify "m=audio(.*)RTP/AVP(.*)115(.*)" "m=audio\1RTP/SAVP\2 115 \3"
So this matches two conditions when RTP/AVP and 115 is there. But I don't know if there is anything specific to m=audio line when crypto is there in your case. Would need to compare two INVITES.
BTW: all normalization scripts can be tested on:
http://sip-profile.54.227.241.219.xip.io/
Leszek
