02-23-2017 03:55 AM - edited 03-18-2019 12:12 PM
Hi everyone,
Im trying to configure SIP Trunk between S4B and CUBE. CUBE is next connected to PSTN provider.
When i try to call from S4B to mobile phone number everything is ok. I can make a call. Problem is when i try to call back from mobile phone number to PSTN number. Profiles, translation rules and dial-peers are configured right in CUBE. Problem is in SIP header. Maybe i need to configure some voice class sip-profile. When i use WireShark to capture the packets i see this ICMP response for SIP INVITE packet:
ICMP 590 Destination unreachable (Port unreachable)
[Expert Info (Warn/Malformed): Header has no colon after the name]
[Header has no colon after the name]
[Severity level: Warn]
[Group: Malformed]
Header not terminated by empty line (CRLF)
[Expert Info (Warn/Malformed): Header not terminated by empty line (CRLF)]
[Header not terminated by empty line (CRLF)]
[Group: Malformed]
Does anyone know, how to change the packet header?
03-01-2017 11:13 PM
You can create a sip profile and apply to a dial-peer going out to S4B
But before that please post the current header that you see
Devan
03-02-2017 12:48 AM
Hi Devon,
i have already solved the problem. The problem was in dial-peer when i used session transport udp. When i changed udp to tcp I partly solved the problem but i did not hear ringing tone in my mobile device.
This next command solved problem completely. In voice service voip sip i used rel1xx supported PRACK.
This is ma dial-peer to S4B
dial-peer voice 7 voip
description to-Skype
translation-profile outgoing to_skype
destination-pattern *called number*
session protocol sipv2
session target dns:*xxxxxxx.xx:5068*
session transport tcp
voice-class codec 10
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
no vad
I hope it helps someone.
Regards Juraj.
