CUBE support for Request for Assistance Interface NG911
tod.higman
I'm trying to pass a SIP INFO message on an NG911 call with "Content-Type: application/rfai-bridge-request+xml".  The CUBE replies with "Unsupported Media Type".  I have enabled the pass through configs I know to use.  Does anyone here have any experience with this?  Thanks much in advance.
CUBE trace:
Jan 21 23:34:02.609: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INFO sip:7209959303@10.4.15.240:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK0c4d34d4;rport
To: <sip:7209959303@10.4.15.240>;tag=B5EE1854-CC4
Contact: <sip:911010501@10.4.0.10>
Call-ID: 5042F289-822B11E3-B1B5D48C-90210556@10.4.15.240
CSeq: 102 INFO
User-Agent: Asterisk PBX
Max-Forwards: 70
Content-Length: 123
<?xml version="1.0" encoding="UTF-8"?>
<bridge-request >
    <modify-bridge action="drop-last-leg"/>
</bridge-request>
Sent:
SIP/2.0 415 Unsupported Media Type
Date: Tue, 21 Jan 2014 23:34:02 GMT
Server: Cisco-SIPGateway/IOS-15.2.2.T
CSeq: 102 INFO
Content-Length: 0
Snip of CUBE configs:
voice service voip
ip address trusted list
  ipv4 10.4.0.10
  ipv4 10.182.27.228
address-hiding
allow-connections sip to sip
sip
  asserted-id pai
  privacy pstn
  midcall-signaling passthru
  privacy-policy passthru
  pass-thru headers unsupp
  pass-thru content unsupp
  pass-thru content sdp
  no call service stop
dial-peer voice 101 voip
description IP PSAP Connection to SBC
preference 1
destination-pattern 7209959303
session protocol sipv2
session target ipv4:10.182.27.228:5062
session transport udp
incoming called-number .
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description IP PSAP Connection to IP PSAP
preference 1
destination-pattern 911
session target ipv4:10.4.0.10:5060
dtmf-relay rtp-nte
no vad
Manish Prasad
Level 5
Level 5
Hi Tod,
Could you please send accross complete sip message starting from INVITE.
Manish
Thank you for the reply.  Here is the call sequence along with the full config:
Jan 23 20:11:09.177: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:911010501@10.182.27.210:5060 SIP/2.0
Via: SIP/2.0/UDP 10.182.27.228:5062;branch=z9hG4bK3pcko610a0hgeh0td0t1.1
From: ""<7209959303>;tag=SDgqjd501-900b8d0-0-13c4-50022-154933-70b92da5-154933
To: "PSAPCNG01"<911010501>;transport=UDP
Call-ID: SDgqjd501-f47b308d9b8f46e49f4a260547ffeeea-agdn1d0
CSeq: 1 INVITE
Max-Forwards: 69
Supported: replaces
Supported: geolocation
Contact: ;isFocus
Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, REFER, SUBSCRIBE, NOTIFY
Allow-Events: refer, conference
User-Agent: microDATA xSwitch/v3.6.00004.3
P-Asserted-Identity: "" <7209959303>
Geolocation: <7209959303>
Flash-Indicator: Yes
Call-Info: <911010501>;purpose=Called-Number,<7209959303>;Service-Type=VoIP,<7209959303>;Flash-Indicator=Yes,<>efa1983b-b977-e311-812c-3640b5842edf@md-911.com>; purpose=Call-Identifier
Content-Type: application/sdp
Content-Length: 236
v=0
o=Dialogic_SIP_CCLIB 151180768 151180769 IN IP4 10.182.27.228
s=Dialogic_SIP_CCLIB
i=session information
c=IN IP4 10.182.27.228
t=0 0
m=audio 7494 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Jan 23 20:11:09.441: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 23 Jan 2014 20:11:09 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
Jan 23 20:11:09.449: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:911010501@10.4.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bK960C
To: <911010501>
Call-ID: 553F9810-83A111E3-9101D70E-AABE001F@10.4.15.240
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1427551293-2208371171-2432423694-2864578591
User-Agent: Cisco-SIPGateway/IOS-15.2.2.T
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1390507869
Contact: <7209959303>
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <7209959303>
Content-Disposition: session;handling=required
Content-Length: 235
v=0
c=IN IP4 10.4.15.240
t=0 0
m=audio 27172 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Jan 23 20:11:09.453: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bK960C;received=10.4.15.240
To: <911010501>
CSeq: 101 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Contact: <911010501>
Content-Length: 0
Jan 23 20:11:10.449: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <911010501>;tag=as567a7109
CSeq: 101 INVITE
Supported: replaces
Content-Length: 0
Jan 23 20:11:10.465: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "PSAPCNG01"<911010501>;transport=UDP;tag=96086A0-2589
CSeq: 1 INVITE
Content-Length: 0
Jan 23 20:11:11.797: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 232
v=0
o=root 5400 5400 IN IP4 10.4.0.10
s=session
c=IN IP4 10.4.0.10
t=0 0
m=audio 11958 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Jan 23 20:11:11.801: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:911010501@10.4.0.10 SIP/2.0
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bKADFE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jan 23 20:11:11.805: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 236
v=0
s=session
c=IN IP4 10.182.27.210
t=0 0
m=audio 23896 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Jan 23 20:11:12.309: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:911010501@10.182.27.210:5060 SIP/2.0
Via: SIP/2.0/UDP 10.182.27.228:5062;branch=z9hG4bK39jnah1048s1ais1d171.1
CSeq: 1 ACK
Max-Forwards: 69
Contact: ;isFocus
Content-Length: 0
Jan 23 20:11:29.133: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK6dd746dc;rport
To: <7209959303>;tag=96082A4-12C1
CSeq: 102 INFO
Max-Forwards: 70
Content-Length: 121
Jan 23 20:11:29.137: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 23 Jan 2014 20:11:29 GMT
CSeq: 102 INFO
Content-Length: 0
Jan 23 20:11:32.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:7209959303@10.4.15.240:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK5a4e761a;rport
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Jan 23 20:11:32.709: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:LTTMDBC1B2XSR2@10.182.27.228:5062;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.182.27.210:5060;branch=z9hG4bKB18
From: "PSAPCNG01"<911010501>;transport=UDP;tag=96086A0-2589
To: ""<7209959303>;tag=SDgqjd501-900b8d0-0-13c4-50022-154933-70b92da5-154933
Date: Thu, 23 Jan 2014 20:11:12 GMT
Max-Forwards: 70
Timestamp: 1390507892
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1013,OS=162080,PR=1043,OR=179396,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
Jan 23 20:11:32.709: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 23 Jan 2014 20:11:32 GMT
CSeq: 103 BYE
P-RTP-Stat: PS=1043,OS=166880,PR=1023,OR=175956,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
Jan 23 20:11:32.789: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Supported: replaces
Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, INFO, REFER, NOTIFY
Content-Length: 0
ltn-n911-01#show run
Building configuration...
Current configuration : 5140 bytes
! No configuration change since last restart
version 15.2
hostname ltn-n911-01
boot-start-marker
boot-end-marker
enable secret 5 $1$22tF$jD2WpqZG0b/PM6U2hshzg1
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip cef
voice-card 0
voice service voip
  ipv4 10.4.0.10
  ipv4 10.182.27.228
address-hiding
sip
  asserted-id pai
  privacy pstn
license udi pid CISCO2921/K9 sn FTX1449AJS1
hw-module sm 1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description litf-mgsw-80# Fa0/3
ip address 204.131.174.209 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description mnl-priv-11 Serial4/0/0/20:0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/0/0.111 point-to-point
ip address 10.182.27.210 255.255.255.252
ip nat outside
ip virtual-reassembly in
frame-relay interface-dlci 111
interface Serial0/0/0.120 point-to-point
ip address 10.182.27.214 255.255.255.252
frame-relay interface-dlci 120
interface GigabitEthernet1/0
ip unnumbered GigabitEthernet1/0.120
interface GigabitEthernet1/0.111
encapsulation dot1Q 111
ip address 10.4.15.240 255.255.0.0
ip nat inside
interface GigabitEthernet1/0.120
encapsulation dot1Q 120
ip address 10.240.59.2 255.255.255.224
vrrp 120 ip 10.240.59.1
vrrp 120 preempt delay minimum 120
vrrp 120 priority 150
interface GigabitEthernet1/1
description Internal switch interface connected to EtherSwitch Service Module
no ip address
interface Vlan1
no ip address
router bgp 65100
bgp router-id 10.112.100.2
bgp log-neighbor-changes
neighbor 10.182.27.209 remote-as 65000
address-family ipv4
  redistribute connected
  neighbor 10.182.27.209 activate
  neighbor 10.182.27.209 soft-reconfiguration inbound
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 198.36.133.0 255.255.255.0 204.131.174.254
ip route 198.36.134.0 255.255.255.0 204.131.174.254
ip route 198.36.135.0 255.255.255.0 204.131.174.254
ip route 204.131.174.0 255.255.255.0 204.131.174.254
logging facility local5
logging 204.131.174.70
logging 204.131.174.72
access-list 1 permit any
access-list 7 permit any
snmp-server location LTTNCOMLML2 RR024xxx
snmp-server enable traps entity-sensor threshold
snmp-server host 204.131.174.2 version 2c nmstest
snmp-server host 204.131.174.70 version 2c nmstest
tacacs-server host 204.131.174.70
tacacs-server host 204.131.174.2
tacacs-server timeout 2
tacacs-server directed-request
tacacs-server key 7 09445C0D4B021201182825012E21
control-plane
mgcp profile default
preference 1
dtmf-relay rtp-nte
no vad
preference 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
exec-timeout 0 0
logging synchronous
transport input all
scheduler allocate 20000 1000
end
ltn-n911-01#
Hi Tod,
When you enable pass-through , CUBE will not play any role in negotiation and all negotiation will happen end to end. So in you case it will be between "911010501@10.4.0.10" to "7209959303@10.182.27.228".
When "7209959303" sends first INVITE to CUBE , it clearly say it will allow only these headers.
INVITE 911010501@10.182.27.210
Which do not contains INFO header.
I would try by disabling these three first to get CUBE in action.
Manish
