CUC CA signed Multi SAN certificate and self signed certificate
geeta.kumari1
Hi All,
We have a CUC where in we have CA signed Multi SAN certificate added.  We have removed the self signed certificate  ( tomcat-trust ) once they have expired but we can see the self signed tomcat trust certificates are regenerated automatically.
So does it means that self-signed certificates will be always available even though we are using CA certificate.
I have checked the serial number of the " show web-security" and the regenerated self signed certificate which dose not matches , so i believe these are not used by the CUC.
Can anyone please share view on this to better understand the certificate concept.
Geeta
Jaime Valencia
You can only have ONE active certificate per service, you can have multiple x-trust certifcates per service.
java
if this helps, please rate
Hi Java,
If the main CA signed certificate is active, then the X-trust certificate of CA will be also in used I guess.
Also, when we delete the X-trust self signed certificate which are expired, then does the server regenerates automatically and are they anywhere required in any process.
Geeta
What version is this?
Can you post a screenshot of what you see?
Looking at my 12.0 I only see the certificates signed by my CA, even if a couple of them say "self-signed" in the type column, the issued by shows my CA.
java
