11-11-2014 10:44 AM - edited 03-17-2019 12:52 AM
I have a CUC version 10 with sip integration to cucm version 10. Some phones mwi works fine others nothing I cannot see any issues as we can leave messages etc If I go inti the USR / MWI Setings and do a reset all the mwi starts working.
Any ideas?
Any help would be great
11-11-2014 12:22 PM
Do you have sufficient number of ports defined for MWI on CUC side?
11-11-2014 12:35 PM
Chris thanks for reply. I have 200 ports what I did find out the Publisher is running but the Connection Notifier is deactivated on the pub and started on the sub.
I suspect since I cannot activate thru cli that a make primary and back will need to be done.
Thoughts?
