CUCM 11.5 multi SAN certificate error
iptsupport
Level 4
Level 4
Hello ,
I try to generate certificate multi–SAN in CUCM PUB and I got error.
"csr export operation failed for the nodes cup-pub, cucm-sub "
my CUCM version is 11.5
the replication is good.
any idea?
9 Replies 9
Have  you tried restarting the service and try again  generating the CSR?
Response Signature
what is impact of reset "Platform Administrative Web Service" ?
I perform reset but it still problem.
did you restart Cisco Tomcat service?
If you go to Cisco Unified Serviceability menu on the top right corner on the Pub and you go to tools Network Services… if  you select the Sub an click go, do you receive an error?
Please let us know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
I perform reset to cisco Tomcat  and I didn't see any error on the network service .
It temporarily makes unavailable cucm web services such as Corporate directory, EM login and , obviously, the admin pages  for the node you are restarting the service.. but it lasts maximum 5 minutes depending on your deployment.
Carlo
I am waiting for maintenance window .
Are there other tests that can be done? These are servers located in 2 different sites.
if I try generate certificate   from CUCM subscriber I got error on SUB:
"csr export operation failed for the nodes cup-sub, cucm-pub"
(upside from PUB)
You said these servers are spread across different data centers. I assume, the CSR export is working for the nodes in the same Data center and the one failing are on a different node.
Can you share the output of  "show network Cluster"
Response Signature
Based on your information, you are probably hitting the following bug:   CSCvw09332
https://bst.cisco.com/bugsearch/bug/CSCvw09332
As workaround you need to reboot Sub and IMP node.
Carlo
