CUCM 11 with UCCX 9
bo liu
Level 4
Level 4
hello everyone
I have a question about the CUCM 's compatibility
our customer has a CUCM 9 integration with UCCX9
now they want upgrad the CUCM 9 to 11.5
but UCCX has been developed with CRM and the agent client use CAD so the UCCX can't upgarad with CUCM
so my question is whether the UCCX 9 can intergration with CUCM 11.5
Jitender Bhandari
It would not work as the CTI to JTAPI version would not be compatible and your CTI ports and Route point would not register at that point.
Below link has all the compatibility matrix you are looking for.
http://docwiki.cisco.com/wiki/Compatibility_Matrix_for_Unified_CCX
(Rate if it helps)
JB
seanvaid
Level 3
Level 3
No it will not work. I would recommend going to 10.6 on uccx. If I recall correctly, cad was completely removed starting 11. So the latest su of 10.6 should be compatible with cucm 11.5 and keep cad usable.
