cucm 12.5 autoregistration login
Juraj Papic
Level 3
Level 3
Hi all,
I have a cucm 12.5 and I have autoregistration, but every time I get the phone registered I have the login request.
how can I  remove this from the autoregistration?
thanks.
sethainsley
Hi Juraj,
Is the login prompt you are referring to the one where it asks for username, password, and services domain?
If so, this is normal behavior for some phones when they come online in a different network from previous bootup.
You can simply allow it to pass by the login prompt, it will time out after about 10 seconds, then it will proceed to register as usual.
Let me know.
Seth Ainsley
Hello Ainsley,
I'm using the auto registration template, but every time I put omit, after a few seconds I get back the login template, I would like to remove this for the login.
thanks.
