To provide a customer with a greeting on a specified number range, and allow the call to be forwarded to a new number after the greeting played, i want to configure a Hunt Pilot that plays an audio file before routing to an Agent, the Agent being the final called target in this case.
![pescla_1-1670403992999.png pescla_1-1670403992999.png](https://community.cisco.com/t5/image/serverpage/image-id/170043i147CBFC70908EAAF/image-size/medium?v=v2&px=400)
This works fine with just using Default Announcements so far. However, now i want to upload my own file.
So, in the MOH Audio Source Config, i set my own Announcement.
![pescla_0-1670403975488.png pescla_0-1670403975488.png](https://community.cisco.com/t5/image/serverpage/image-id/170042iEF439DDC81530649/image-size/medium?v=v2&px=400)
![pescla_2-1670404010338.png pescla_2-1670404010338.png](https://community.cisco.com/t5/image/serverpage/image-id/170044iBBC4C15E41BBE64B/image-size/medium?v=v2&px=400)
Then, in my Announcement i simply upload my .wav file. I double checked that the format is correct - 16bit Signed PCM, Mono, 8khz Sampling. Upload works fine.
![pescla_3-1670404060637.png pescla_3-1670404060637.png](https://community.cisco.com/t5/image/serverpage/image-id/170045iB9A224F7CC95DC07/image-size/medium?v=v2&px=400)
But in the end when i call the Hunt Pilot im still always only hearing the "AttemptsExceeded" Default Announcement that i configured. When i set "Default Announcement" to None, i just hear a slow beep tone.
What did i do wrong that causes my "Announcement by Locale" to fail? The phone that i am doing the call with (CIPC) has both User and Network Locale set to English, United States.
I saw that this seems to be a commonly known problem however i didnt find any solution to this https://community.cisco.com/t5/unified-communications-infrastructure/cucm-11-0-hunt-pilot-queue-custom-initial-announcement-not/td-p/4008782
