12-28-2023
04:23 AM
- last edited on
12-28-2023
07:32 AM
by
rupeshah
I have two callmanagers in a cluster (2 UCS M4 BE6K), the publisher after a power outage lost 2 hard drives (Number 3 and 6 in Raid 5), if i replace the hard drives with new ones I will solve the problem.
12-28-2023 04:25 AM
Yes, as soon you replace the faulty drives with the new ones, the RAID will rebuild and adjust with the new drives. Just do one drive at the time.
12-28-2023 05:52 AM
I have the same problem. Should I replace the damaged disks with new ones with the same size and the same manufacturer with the same characteristics?
Or just a disk with the same size and speed
