01-05-2011 09:38 PM - edited 03-16-2019 02:42 AM
Can any tell me how can i check the extension mobility logs in call manager.when user login and logout time details.We are using version 7.0.1.11000-2.
Thanks and Regards
Sajeel Akram
01-05-2011 10:11 PM
Hi Sajeel
In the newer versions of CUCM, we have "Cisco Unified Reporting tool" Under that for Extension Mobility we can generate report
Cisco Unified Reporting-->Unified CM Extension Mobility-->Generate Report.
Unfortunately this doesn't give a history of past logins and events. It only displays current information.
The history of EM login/logouts can be collected from the log files.
Using RTMT tool, we can just get the total number of completed login/logouts but not the details of EM users who performed login/logout.
I don't think there is any other way.
Regards..
Mahesh Dawar
03-07-2011 08:29 AM
Has there been any progress made in the ability to view login records?
We have around of wireless phones at my facility using Extension Mobility. I am looking for a way to verify the last person to login to a phone. There have been many times that a phone breaks a week before we are told. Is there a way to view a history of logins per phone so I can see who broke the phones?
Troy
10-03-2013 03:31 AM
Hi everyone,
I would like to repropose this topic as it's something that could come in handy to several people, it seems.
Any one has an idea if there is a way to get a history of extension mobility log in log outs?
thank you,
Mike
10-03-2013 03:47 AM
There is no such tool which will provide a report of extension mobility logins and logouts in the past. The only option is to capture detailed Extension mobility traces and the login messages are pretty clear , eg you will see something like "EM Request for xyz" in the trace where xyz is the name of the user. It should be easy enough to filter such messages and generate a report.
Manish
