CUCM 7.1.5 Database Status Error
CN_donke.xu
Hello Friends
I try to install cucm 7.1.5 on a VMware,but when i finish it ,i met a database error:
All servers do not have a replication count of 427.
I try to restart the VM server or  install this in another pc  but the database status still is All servers do not have a replication count of 427.
who know this,and what can cause such a mistake
Thanks&Best Regards
Donke xu
Manish Gogna
Hi Donke,
Since this is an unsupported deployment ( 7.x on VmWare ) and also no TAC support for 7.x versions, you should try a reinstall by performing a media check and see if this helps as the server reboot has already been tried.
Manish
Manish Gogna
Hi Donke,
Manish
HI Manish
Thanks for you advice, i had got it.
