CUCM 8.5.1 with vmware ESXi 5 on UCS C250 M2 support?
csco10663538
Hi all.
My name is Jcob Shin.
I`m Korean.
So I can`t speak English.
But I have question and I want to know this information.
Now my customer use the CUCM 8.5.1 with vmware ESXi5 on UCS C250 M2.
Unfortunately it was happen problem. T.T
Problem is Vmware host error.
Error message is I/O latency timeout.
But I have doubts C250 M2.
Because I tried to search the CUCM 8.5.1 with C250 support text but I could not it.
Maybe if you know it then reply to me.
Thank very much for read my poor English text.
Jaime Valencia
Have you already reviewed the virtualization wiki??
Unified Communications in a Virtualized Environment
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
That server doesn't show in the
Tested Reference Configurations (TRC)
http://docwiki.cisco.com/wiki/Tested_Reference_Configurations_%28TRC%29
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
csco10663538
Thanks Java.
Check thet LRO is disabled in VMWare, if I don't remember wrong these are some or the errors you can get if you don't disable LRO.
http://docwiki.cisco.com/wiki/Disable_LRO
Even though the C250 M2 isn't "Tested Reference Configurations" it should be OK for "Specs-Based VMware Hardware Support"
Br.
Maciej
Thanks for Maciej.
Yes. UCS C250 M2 is not TRC.
It`s specs-based server.
I could not found compatibility of CUCM 8.5.1 with C250 M2.
But CUCM 8.5.1 with VMware ESXi 5 compatibility found.
Now It opened case.
If it will clear then I will reply that.
Thank you so much.
