In reviewing a reported problem with a CDR record, the originalCalledPartyNumber and finalCalledPartyNumber fields appear incorrect. Incorrect meaning that instead of a number I see a sequence entry b00404302030.
These users do have many features enabled and the called numbers may also be andestination with many features enabled. e.g. Shared, with voicemail, Extension Mobility, SNR/Mobility, etc.
Has anyone else seen this behavior and what is this? How can we interpret the information in those fields?
Cheers
When you see that value in CDR, a conference could be involved.
Check this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/cdrdef/cdrex.html#wp1218454
Hope yo help, please remember yo rate if it does.
Regards!
Thats the bridge id for your call, that means it was a conference call and allows the system to keep track of participants on conference calls.
