CUCM 8.6.2 to 10.5 Upgrade Fails at Installing DB Component
kylelafleur.kl
The following is the message I get when the post install / installing db components are at about 83% complete. I have rebuilt the server as multiple TAC cases have revealed that my CUCM server is possibly corrupted. This is the exact same thing that happened before the server was rebuilt.
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
"/usr/local/cm/script/cm-dbl-install RU PostInstall 10.5.2.18900-15 8.6.2.20000-2 /usr/local/cm/ /common/component/database /common/log/install/capture.txt " failed (1)
The system will now halt.
Sifting through the install logs more I find this:
12/08/2019 08:24:49 IPM|Internal Error, File:ipm.c:2011, Function: ipmReadNormalizedInputLine(), "/usr/local/cm/script/cm-dbl-install RU PostInstall 10.5.2.18900-15 8.6.2.20000-2 /usr/local/cm/ /common/component/database /common/log/install/capture.txt " failed (1)|<LVL::Critical>
12/08/2019 08:24:51 IPM| end-of-session "Installing database component": 1094.434 secs.|<LVL::Info>
12/08/2019 08:24:51 IPM|Close progress meter "Component Install"|<LVL::Info>
12/08/2019 08:24:51 component_install|Writing database into /common/log/install/component_failed.xml file.|<LVL::Info>
12/08/2019 08:24:51 component_install|File:/opt/cisco/install/bin/component_install:817, Function: exec_progmeter(), /opt/cisco/install/bin/progmeter failed (1)|<LVL::Error>
12/08/2019 08:24:51 appmanager.sh|Internal Error, File:/usr/local/bin/base_scripts/appmanager.sh:276, Function: refresh_upgrade(), failed to refresh_upgrade infrastructure_post components|<LVL::Critical>
12/08/2019 08:24:51 post_install|File:/opt/cisco/install/bin/post_install:1021, Function: install_applications(), /usr/local/bin/base_scripts/appmanager.sh -refresh-upgrade failed (1)|<LVL::Error>
Any insight would be greatly appreciated, I am running
CUCM 8.6.2
1 Publisher, no subs
~ 250 Phones
VMWare 5.5
I went ahead and posted my trace logs from database and install / upgrade
George Sotiropoulos
I would strongly suggest to open a TAC case with Cisco
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
monster.speaks
I am assuming you have already checked the used/available disk space.
You might want to reduce the syslogging size on the nodes.
