CUCM 9.x support MS AD2000 ?
Kia Seng Ronald Tan
Dear members
Does anyone know if CUCM 9.x supports MS AD 2000?
Some doc reference say yes some say no.
What alternatives do we have if MS AD 2000 is a must?
Jaime Valencia
Configure LDAP directory
If you want to do so, you can add users from your corporate directory to the Cisco Unified Communications Managerdatabase by synchronizing the user data to the database. Cisco Unified Communications Manager allows synchronization from the following directories to the database:
  • Microsoft Active Directory 2000
  • Microsoft Active Directory 2003
  • Microsoft Active Directory 2008
  • Microsoft Active Directory Application Mode 2003
  • Microsoft Lightweight Directory Services 2008
  • iPlanet Directory Server 5.1
  • Sun ONE Directory Server 5.2
  • Sun ONE Directory Server 6.x
  • OpenLDAP 2.3.39
  • OpenLDAP 2.4
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010100.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
