07-07-2017 04:15 AM - 편집 03-17-2019 10:43 AM
Hi ,
we have new implementation for CUCM and cisco ip telephony project
and the integrator recommend to use sip for ip telephony
but now I m reading about some limitation for using sip over sccp , but that in old threads cause I m not expert in ip telephony
so can someone advice me if there is really limitation in using sip over sccp for cucm with cisco ip phones ?
and if there is limitation what are the features that can not be used in sip while using sccp ?
해결되었습니다! 솔루션으로 이동.
날짜: 07-07-2017 05:50 AM
All new Cisco phones (88XX, 78XX) are SIP only. Which models are you deploying?
With current version of CUCM the feature parity between SIP and SCCP is pretty much the same.
날짜: 07-07-2017 09:33 AM
we have 7811 and 8841
날짜: 07-07-2017 11:45 AM
Then nothing to consider here as these only support SIP :-)
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
