05-19-2020 11:43 PM
Can you register a Cisco Unified IP Phone (7900 series) with a distant CUCM but have the firmware files for the phone downloaded from a local CUCME
05-20-2020 07:12 AM
Yes
Indicates that the phone will use an alternative server to obtain firmware loads and upgrades, rather than the defined TFTP server. This option enables you to indicate a local server to be used for firmware upgrades, which can assist in reducing install times, particularly for upgrades over a WAN. Enter the hostname or the IP address (using standard IP addressing format) of the server. The indicated server must be running TFTP services and have the load file in the TFTP path. If the load file is not found, the load will not install. The phone will not be redirected to the TFTP server. If this field is left blank, the phone will use the designated TFTP server to obtain its load files and upgrades. | |
Maximum length: 256 |
05-20-2020 07:59 AM
Awesome! I’ll try this as soon as I can. Thanks
