CUCM Configuration Change Notify
Amit23
Level 4
Level 4
I am having BE6K CUCM, CUC and IMP version 10.5.X.
i am looking for solution in system with that if any changes happened to current running configuration, system should provide the notification to admin user.
would be this setup possible with in BE6K or not?
if yes how can we apply and see results?
Warm Regard's
Amit Sahrma
You can't get this natively from B6k. You can use Cisco Prime Collaboration or look at this URL.
http://www.uplinx.com/configuration-tracking/
