CUCM / CUC - TCP / UDP Port Requirements for an IP Phone
Hello:
I am testing a Cisco IP Phone (e.g. 7942) and attempting to determine what TCP / UDP Ports that the Cisco IP Hard Phone (i.e .7942) requires to fully function / access CUCM / CUC.  The below is what I have tallied from the listed Cisco documentation.  A Peer Review of the TCP / UDP Requirements would be appreciated as I am only concerned about the Cisco IP Phone obtaining Dial Tone, making / receiving Phone Calls and access / leave / retrieve Voicemails.
  1. CUC (Unity Connection Voicemail / Auto Attendant / Call Handlers)
Source: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/security/b_11xcucsecx/b_11xcucsecx_chapter_00.html
  1. Service Ports
Ports and Protocols1
Operating System Firewall Setting
Executable/Service or Application
Service Account
TCP and UDP ports allocated by administrator for SIP traffic.
TCP ports 5001, 5002, 5003 and 5004 are open.
Possible ports are 5060–5199
Open
CuCsMgr/Unity Connection Conversation Manager
ucsmgr
Unity Connection SIP Control Traffic handled by conversation manager.
SIP devices must be able to connect to these ports.
UDP: 16384–21511
Open
CuMixer/Unity Connection Mixer
cumixer
VoIP devices (phones and gateways) must be able to send traffic to these UDP ports to deliver inbound audio streams.
TCP: 21000–21512
Open
cucsmgr
IP phones must be able to connect to this range of ports on the Unity Connection server for some phone client applications.
UDP: 16384–21511
Open
cumixer
  1. Outbound Connections Made by Unity Connection
Ports and Protocols
Executable
Service Account
TCP: 2000* (Default SCCP port)
Optionally TCP port 2443* if you use SCCP over TLS.
* Many devices and applications allow configurable RTP port allocations.
CuCsMgr
cucsmgr
Unity Connection SCCP client connection to Cisco Unified CM when they are integrated using SCCP.
UDP: 16384–32767* (RTP)
CuMixer
cumixer
Unity Connection outbound audio-stream traffic.
  1. Secure Transport Layer
Ports
Service Account
cucsmgr
Unity Connection SIP Control Traffic handled by conversation manager. SIP devices must be able to connect to these ports.
  1. CUCM Functionality with a Cisco IP Phone Port Requirements
Source: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/sysConfig/11_5_1_SU1/cucm_b_system-configuration-guide-1151su1/cucm_b_system-configuration-guide-1151su1_chapter_01010101.html#CUCM_TP_IBA67974_00
I have the IP Address of the CUCM Publisher / Subscriber:
Unified CM 1                    3.30.64.11 Active
Unified CM 2                    3.30.64.12 Standby
Unified CM 3                    3.30.64.13
I am not able to verify the CUCM Version as the version shows up after initial logon.  In consulting the Cisco Unified Communications Documentation, the following are the Required Ports for IP Phone functionality with the CUCM.
  1. Common Service Ports
From (Sender)
To (Listener)
Destination Port
Purpose
Endpoint
CUCM
1090, 1099 / TCP
Cisco AMC Service for RTMT performance monitors, data collection, logging, and alerting
Endpoint
Unified Communications Manager
7
Internet Control Message Protocol (ICMP) This protocol number carries echo-related traffic. It does not constitute a port as indicated in the column heading.
Endpoint
Endpoint
22 / TCP
Secure FTP service, SSH access
Endpoint
Unified Communications ManagerDNS Server)
Ephemeral / UDP
Cisco Unified Communications Manager acting as a DNS server or DNS client
Note
Cisco recommends that Cisco Unified Communications Manager not act as a DNS server and that all IP telephony applications and endpoints use static IP addresses instead of hostnames.
Endpoint
Unified Communications Manager (DHCP Server)
67 / UDP
Cisco Unified Communications Manager acting as a DHCP server
Note
Cisco does not recommend running DHCP server on Cisco Unified Communications Manager.
Endpoint or Gateway
69, 6969, then Ephemeral / UDP
Trivial File Transfer Protocol (TFTP) service to phones and gateways
Endpoint or Gateway
6970 / TCP
Trivial File Transfer Protocol (TFTP) between master and proxy servers.
HTTP service from the TFTP server to phones and gateways.
Endpoint
8443 / TCP
Used for Cisco User Data Services (UDS) requests
  1. Web Requests From Cisco Unified Communications Manager to Phone
From (Sender)
To (Listener)
Destination Port
Purpose
·       QRT
·       RTMT
·       Find and List Phones page
·       Phone Configuration page
Phone
80 / TCP
Hypertext Transport Protocol (HTTP)
  1. Signaling, Media, and Other Communication Between Phones and Cisco Unified Communications Manager
From (Sender)
To (Listener)
Destination Port
Purpose
Phone
53/ TCP
Session Initiation Protocol (SIP) phones resolve the Fully Qualified Domain Name (FQDN) using a Domain Name System (DNS)
Note
By default, some wireless access points block TCP 53 port, which prevents wireless SIP phones from registering when CUCM is configured using FQDN.
Phone
Unified Communications Manager (TFTP)
Trivial File Transfer Protocol (TFTP) used to download firmware and configuration files
Phone
2000 / TCP
Skinny Client Control Protocol (SCCP)
Phone
2443 / TCP
Secure Skinny Client Control Protocol (SCCPS)
Phone
2445 / TCP
Provide trust verification service to endpoints.
Phone
Unified Communications Manager (CAPF)
3804 / TCP
Certificate Authority Proxy Function (CAPF) listening port for issuing Locally Significant Certificates (LSCs) to IP phones
Phone
5060 / TCP and UDP
Phone
Phone
5061 TCP
Secure Session Initiation Protocol (SIPS) phone
Phone
Phone
6970 TCP
HTTP-based download of firmware and configuration files
Phone
6971, 6972 / TCP
HTTPS interface to TFTP. Phones use this port to download a secure configuration file from TFTP.
Phone
8080 / TCP
Phone URLs for XML applications, authentication, directories, services, etc. You can configure these ports on a per-service basis.
Phone
9443 / TCP
Phone use this port for authenticated contact search.
IP VMS
Phone
16384 - 32767 / UDP
Real-Time Protocol (RTP), Secure Real-Time Protocol (SRTP)
Note
Cisco Unified Communications Manager only uses 24576-32767 although other devices use the full range.
Phone
IP VMS
0 Replies 0
